What OS are you running? If it is a supported version of maOS or Windows it should work fine. If you are using Windows you might be able to use Alexa voice control from an Echo Dot or installing the Alexa app on the Windows machine.I will not use WIII mini ...Will this work ?.....Computer USB to Dac USBC and XLR from Dac to powered speakers ...Is that right ? How would I bypass the computer from processing ? Will this be bit perfect ? Thank you so much
