https://audiosciencereview.com/forum/index.php?forums/member-area.36/Hi just joined
I agree with you.Hello,
We are supposed to don't know about the measured performance of either the M500 (@amirm is waiting one for review) or your preamp.
Still, SMSL published a measurement showing 117db SINAD (at 6V):
If that is true, I don't know much preamp which may perform better than this.
In general, DAC outputs are cleaner than analog preamp outputs. And without channel mismatch due to digital volume control (Again, in general)
So, theoricaly, it would be better to use your M500 straight to your power amp.
It can’t make the sound more accurate.So preamp cant improve sound even if I like the sound of it
Never. The preamp may only transmit the original signal of the DAC in best cases. Or degrading this signal, in worst (most) cases.So preamp cant improve sound even if I like the sound of it
Would you say, for instance, that using the JDS Lab Atom as a pre-amp after a fixed voltage DAC will not give as clean sound as, say, a DX3 Pro used in pre-amp mode?
Nope. Thats why I said "in general". "Most" DAC outputs are cleaner. Of course, a Benchmark HPA4 will not degrade a Topping D50s signal, for example, but it will not improve it either. The Atom will transmit the DX3 Pro output as it is , without adding or removing performance to it.Would you say, for instance, that using the JDS Lab Atom as a pre-amp after a fixed voltage DAC will not give as clean sound as, say, a DX3 Pro used in pre-amp mode?
