Can I connect my Astell&Kern A&norma SR25 MKII portable music player to my amp? I have Kanto YU6 powered speakers.
I’ll just copy & paste the connections from the description:
- dual Toslink optical digital audio inputs
- optical digital inputs support up to 24-bit/96kHz input (two-channel PCM only)
- analog stereo RCA input with phono switch
- analog 3.5mm auxiliary input (6.5-foot cable included)
If the answer is yes, what cables would I need? Where would you suggest connecting it? Would I need some sort of “cradle” for the portable? “Cradle” is probably not the correct terminology.
Feel free to offer suggestions of other digital players as alternatives. That should probably be a separate thread. Links to other threads on digital players would be appreciated if you think that is the route I should go.
I mostly listen to FLAC when I go digital, btw.
I also have a Marantz CD6007 CD player. I don’t know if connecting a portable music player to that is an option.
I plan on getting a turntable soon (another potential thread). I know I won’t be able to connect all of the above components at the same time to my powered speakers unless a splitter is an option.
Thanks for any suggestions. I hope I chose the correct subforum.
