So, I am installing my personal Linux for some coding and I am interested in setting up some proper DSP there as well.
So far, PulseEffects seems to be the easiest to set up yet I could not figure out how to use it properly.
My main question is that I have no idea what are those 'mode' in multi-band equalizer suppose to mean, for example: RLC(BT), RLC(MT), BWC, LRX, APO....
While all those 'modes' provide me with the same Q, Gain, and Freq options to tweak with, I found the REW measurement results are totally different... I have no idea why this is the case... I assume that with the same parameter they should at least work the same... it is just a matter of impelementation. (clearly it's not)
Also, I found EQing in Linux a bit confusing to me. And to my best understanding (I am a Linux noob), If I want something else other than PulseEffects, I need to install a plugin host and some pulgins downloaded from other sources, yes? Do you guys have some decent plugin hosts to recommend? I used some by found them lack of documentation or how-to-setup, e.g. Carla.
I just want some peace-of-mind Equalizer that works the same as Equalizer APO under Windows so that I could leave this problem alone and not be bothered by it anymore.
