Vasr
- Joined
- Jun 27, 2020
- Messages
- 1,409
- Likes
- 1,922
- Thread Starter
- #21
Software like Jriver make things simpler (at a cost) but it is a walled garden approach. It is like a soft-AVR on its own and they have done a good job. But everything has to be done from inside JRiver.
My experiment being described in this thread is to create a general solution that will work for any content player on the PC one may want to use and/or don't to pay for JRiver. For people who may want to do this instead of buying an AVR or going through a commercial solution like JRiver in a walled-garden approach.
If you are using pass-through of the encoded audio to a preamp processor then there would be no decoding and so no latency issues of course. But if you have pre/pro available, the case for paying for JRiver is weaker. YMMV.
The latency here has nothing to do with the power of the processor. Any software decoding of even the simplest codec like AC3 is very slow. But if you have a single player doing both audio and video rendering, then they have control over both to keep them in sync. If you have a weak CPU, it requires more time to buffer ahead and start. All media players do this - Kodi, MPC-BE, VNC, etc.I've used JRiver for ages, and sent the video to the monitor via HDMI while sending the audio to whatever preamp/processor I'm using via USB and never have I had severe latency issues, but then again I use an I7 with 16 gb of memory and a Samsung Evo SS drive. So no problems with latency.
