I’ve been playing with this loudspeaker idea for a while > a fully active four-way system based on
the B&C 18HTX100
and the Beyma 18QLEX1600Fe.
What attracts me to the 18HTX100 is its unusual construction. It combines a relatively light 18-inch cone with the B&C DCX464 coaxial compression driver, already integrated with a horn designed specifically for it. In effect, the 18HTX100 is almost a complete three-way system in a single Chassis. The 18-inch cone handles the lower midrange, while the coaxial MF/HF compression section covers the rest through a common horn.
Rather than asking the 18-inch cone to produce deep bass as well, I would prefer to use it only where it should be most comfortable, roughly 100/120 to 600 Hz. Below that, the Beyma 18QLEX1600Fe would take over, as its very strong motor and low-frequency parameters seem much better suited to true bass duty.
The approximate layout would therefore be:
Beyma 18QLEX1600Fe: 25/30–100/120 Hz
B&C 18HTX100 LF: 100/120–600 Hz
DCX464 MF: ~600 Hz–4 kHz
DCX464 HF: above ~4 kHz
The whole system would be fully active and DSP-controlled, so crossover frequencies, levels, delay, phase and EQ could all be optimized from measurements rather than fixed in advance.
Physically, I imagine a fairly tall enclosure with the two 18-inch drivers arranged vertically. The 18HTX100 would need to sit high enough for the integrated horn to be approximately at ear level, while the QLEX could occupy its own bass-reflex chamber below. The result would obviously be large, but not dramatically wider than the 18HTX already requires.
In my opinion, the 464 is a very good compression driver that also measures very well. As for the Triax itself, the only reliable measurements available so far are those from B&C. They’re usually trustworthy, but it wouldn’t hurt to see some independent measurements before making a purchase.
The appeal lies in the division of labor: a massive radiating surface and very little excursion in the upper bass/lower midrange, the integrated DCX464/horn system with controlled directivity above it, and a special 18-inch woofer below it, dedicated exclusively to reproducing the deep bass.
It’s a bit oversized, but I’m definitely tempted to build it.
