Complete beginner needing advice
At that budget, I would get a pair of Adam T5V. USD$200 each, or $400 for a pair. I have seen them on the secondhand market for USD$250 a pair. These speakers are active, so only need a line level input and a power cord. This means you don't need that Wiim amp, you could get a Wiim Mini at USD$89. That would be a pretty nice system for under $500. Maybe more than $500 when you throw in things like speaker stands, cables, etc.
What are your thoughts on the monoprice 8' 60 watt sub ?
Depends, what are your hopes and expectations? Someone like me living in an urban apartment might never come close to pushing it to it's limits. But if I were more of a gamer or action-movie fan, that might be another matter!
My office desk system consists of a cheap Polk 10" sub (was about $130) paired with Vanatoo T0 speakers. The Polk is certainly not a premium subwoofer, but it smooths and extends the low end nicely down to around 40-45Hz according to REW. I am, however, using a minidsp 2x4HD for room correction and EQ which helps a lot. So, yes, an inexpensive sub can provide some benefit for casual or lower volume listening. Depends on the use case.
That is a very good option for that price. The OP could even dial in the eq in the WiiM (see ASR review).
Based on this review https://www.audiosciencereview.com/...re-elite-es20-review-bookshelf-speaker.33834/
Also based on other's opinions it seems to be highly regarded, and at $319 I think it is within my budget and a good value for money.
Agreed.
I missed in error your comment that you had already purchased the Sony loudspeakers.
If they are still in a 'return window', consider returning them for an alternative.
If you cannot return the Sony loudspeakers, add a competent (used ?) subwoofer and use the room correction feature and Parametric EQ of a WiiM Amp for control over the sound.
Consider the alternative of saving up for a loudspeaker with the measured performance of the $995/pair AsciLab F6B loudspeaker:
Compared to the Polk Audio ES20, the measured performance (and perhaps, cost) of the F6B 'may' reduce the feelings of an itch to upgrade your loudspeakers in the future. ;)
Regarding speaker stands,
The $99.99/pair option at the link below has a different aesthetic than the Monoprice stand:
I read no mention adding of 'spikes' to the base for a carpeted listening space.
I do not know but it appears this stand is constructed mostly of solid wood.
