it is very complicated. pretty sure automatic stuff like Dirac doesn't get even near to the limits....aka will only correct up to a point.
you see, one big problem with the GD is that it obviously is noise poluted....plus in the bass region you reading will be influenced by the type of window.
here is another corrected IR I made of OPs left speaker today (this time I also corrected FR). here is excess group delay with the window he chose 500/500
tons of noise.
if we look at the impulse we can make the window much smaller and filter out part of the noise.
here is 30/200
Much cleaner. We still cannot be sure what the noise is.
Another thing that is confusing, at least for me, is the relationship between excess phase and peak energy time.
A perfect impulse will have both of them flat.
However, in-room response can only be one or the other. We can create a perfectly flat peak energy time by completely inverting the phase, but this introduces a lot of pre-delay, which is visible in the excess phase as well.
Also, the graph I posted clearly shows negative excess group delay below approximately 55Hz. However, the phase and peak energy time are flat down to 22Hz. Which reading is correct? It's puzzling.
peak energy time is free of noise, but the peak beeing at zero doesn't garantee there is nothing coming in to soon, isn't it?
In the end, when we apply phase correction to the extreme, we have to verify it by ear since there doesn't seem to be a clear indication. Of course, we can play it safe by applying less correction and keeping everything above zero. But for this, we can use automatic tools like Dirac. Unfortunately, there seems to be a lack of a graph specifically for this purpose. What does the group delay show, after all? It shows a single "line," while we know there are reflections. The wavelet kind of shows reflections, but then again, the reading is very confusing and heavily dependent on the smoothing. And smoothing itself is problematic since it obscures reality, doesn't it?
Correcting frequency per frequency in Rephase is probably the most accurate way to do it. However, I believe it should be possible with the tools provided by REW.
As I mentioned, I am experimenting. I think it's advisable to work with different frequency-dependent windows over the spectrum. After all, the frequency-dependent window in REW is limited compared to other DRC (Digital Room Correction) software where you have more control over the windowing. We can merge different windows together.
I don't even think this is all worth it. the diferences are subtle. but we are all here for the subtle diferences in this forum lol
