- Joined
- Nov 3, 2020
- Messages
- 741
- Likes
- 1,316
Well said!But it is really better to get what is needed.
It has nothing to do with consumer protection.So you do not believe in consumer protection
You are missing the point. You say we don't need Hi-Res. That is not the argument here.It has nothing to do with consumer protection.
If you are daft enough to believe that 10× the bandwidth of human hearing is required for delivery of recordings then you should be reasonably happy with the noise that is an unavoidable physical consequence of that excess bandwidth.
I can produce wonderfully quiet recordings if you are happy to restrict the bandwidth to about 25kHz.
No comment neededHigh rez just gets you a zoomed in view of empty or erroneous information. It’s presence can only lead to downsides.
But the limiting factor is not usually the recording/editing technologies.Contrary to what you say recording systems do exist that deliver the full potential of High Resolution
Watch @amirm's video and notice that there is music correlated signal all the way up to 100kHz. Are you going to argue with that? Is your job as a recording engineer not to capture what is being played? Or do you think you know best and nothing above 25kHz should be recorded?If you are daft enough to believe that 10× the bandwidth of human hearing is required for delivery of recordings then you should be reasonably happy with the noise that is an unavoidable physical consequence of that excess bandwidth.
Don't live in muckville then, move to a place where there is no muck!“The wider you open the window the more muck gets in”
Had they ever started with saying "we want a 16-bit 44.1kHz recording"? I'm curious; when you last recorded an acoustic session, if I may ask?In my entire career I have never known a producer who set out, at the commencement of a project, to create a work in "high resolution".
I am sure you will allow others to have a different view. Especially as they managed to make high-resolution an industry standard...I have never encountered any actual evidence in support of the view that anything significantly greater than 16/44 is necessary or desirable.
It is above 150kHz and at below 100dBFS. How do you expect to hear it? Most likely caused by an edit.Can anyone explain the jumps at 3:50 to the very right. The entire scale jumps, this is too high to be drums, but the fact that the entire spectrum jumps is odd, because I don't hear it in the music?
The fact that there might be correlation should not be taken as evidence that it's actually desirable content. Jitter sidebands and other distortions are highly correlated to the wanted material. Does this make them desirable?there is music correlated signal all the way up to 100kHz
No, the job is to capture what people want to hear*. Most analogue consoles have very distinct low pass filters in their outputs because the presence of ultrasonics is clearly deleterious to analogue recording. The fact that we now have technologies capable of preserving the unwanted garbage does not constitute a reason for doing so.Is your job as a recording engineer not to capture what is being played?
You may pay me to record anything you wish; I will happily take your money. But my advice to you is that to do so is more likely to be deleterious to the overall results than to keep it clean above, give or take, 20kHz.do you think you know best and nothing above 25kHz should be recorded?
Just found out that Audition (2021) cannot play DxD files as its playback engine is limited to 192kHz sampling rate.
If anyone's interested, the link to download MusicScope is here. It looks like the company closed down back in 2019, so they did the decent thing and put up an open link for past customers. Since thye don't exist anymore they probably won't come running after you for downloading it.The tool, musicscope seems to be offered for free now although there is stipulation that you have to be an existing customer (?).
Another fine analysis explaining why we should not bother downloading hi-res files. You pay for a lot of garbage.Yes, another older high-resolution music format comparison, this time with a different twist than the previous ones:
I posted the error message that Audition displayed when I tried to open a DxD file, which by standard is sampled at 24bit / 352.8 kHz. I tried this on two Windows 10 PCs, each less than two year old with i9 and i7 CPUs and 32 and 16 GB memory respectively. Here is a short clip if anyone care to test.This may or may not be correct for DxD files, but will work for uncompressed PCM Wav files
May I ask you to please explain what you mean by "artificial"? Also please note that, I said playback DxD file, not create or convert WAV files.Audition's create and convert limits are artificially imposed upon you
Thank you but can you please tell me how am I going to try those editing software “in Audition”?and if you want to try up to 64bit / 384Khz (or higher) audio files in Audition....
Then try these >
TASCAM High-Rez Editor
DSD/PCM
https://www.tascam.eu/en/hr-editor.html
Aul Converter (up to 64bit audio)
https://samplerateconverter.com/wav/convert-rf64
