Where did you get this nonsense from? Please cite examples.
You don't sell / manufacture class A/B amps by any chance?
I don't sell any audio gear. You guys like this technology, and I get that. Some of you make it. This technology has been great, and it has many wonderful uses. I'm not storming through any doors, I simply walked by and overheard the chatter. I do have McIntosh equipment, but I also have Marantz equipment and Onkyo equipment and have had many others. There are those that like various specifications and you can always pick them to death.
I am sorry that some of you took it the wrong way, I am not trying to call anyone ignorant (despite a lack of reciprocity there) I simply do not think some of you are familiar with McIntosh core technologies, which like any product, some will like and others won't. This surprised me. I do not ever recall coming across this before. I have no doubt that you can understand them, and that you can teach me a thing or two, but I wish that these things were better understood before we just dove in to compare two very different technologies.
The autoformer- it is an impedance matching transformer, yes it will spec differently depending on which outputs you use, but you know what I meant, it is meant to impedance match the amp to the speakers and gain the associated benefits of that. I thought that was understood when I said "the same".
Power Guard- Yes, I know what clipping sounds like and would never purposely drive an amplifier into that. Knowing what we know about the intensity of sound and the way we hear, it is not really uncommon for a more quiet part to be hundreds of times lower than the louder parts. Take the Interstellar score for example. For whatever reason people in these circles don't appreciate this, but in the OEM car world most everyone has adopted it one way or another so they don't have to replace speakers under warranty. Clipping can occur when you can't even hear it, and that's when tweeters get fried. Cumulative heating on tweeter coils from distortion is a real issue, and it burns up expensive speakers just the same as others. I think the bad assumption here is that any time the amp is in clipping it is intentional and the user should just not do that.
If the amp has powerguard, I can set the volume at whatever and don't have to worry that the next song might have some unknown passage that would fry my speakers before I got to turn it down. I should not have used the word "fear". I should have said irresponsible. I primarily deal with speakers, and I will tell you that I find it irresponsible to use an amplifier without clipping protection at more than .01 of it's rated output for average listening. So if your amp is 350w, that's 3.5w. That's being responsible. And you better hope you know what this level is since there is no way to tell what the amp is putting out.
Now, feel free to continue a conversation about this spec vs that spec (I did skip over a bunch, due to the nature of the class D amp several will be better, no need to even look at it)
And finally, if you own a McIntosh product and want to compare it to another, you should call the factory where they make it, in NY, and ask. They do not rate their components at the industry standard for power output because that industry standard is trash, and like I said it is meaningless. If the specs you want exist, they will give them to you. If the cost of the amplifier is a driving force for you, then 1/7th the cost should be where the conversation ended. It is cheaper. No doubt.
The ironic thing is I meant what I said, I do think these amplifiers have many good uses and I bet eventually someone will ask me what they should get and this will fit the bill, and I will recommend them. If you like McIntosh and their core technologies, this is not for you. That is the point of my post. If the OP seems to be considering trading a 252 for some of these. I do not think that is a wise decision. Not only does he already have the 252, which is a really great amp, but even if this other amp was actually "better" via the specs beaten to death here, it would not represent a noticeable improvement in sound, if even a measurable one once it was running actual speakers. And, as I have said, even if that amplifier can do 350w, it should never be used at more than 3.5w continuous, except in very controlled conditions. I would also place some value on the fact that the McIntosh will always be supported and service parts available by a company that is over 70 years old.
