yeah think what you want. i'll refer you to the title of this thread so i'm not the only one that's hearing a difference between rippers.
Yes. People also claim to hear differences between DACs or amps and then continue to fail
level-matched blind tests. Nobody disputes that you are convinced to hear differences. However, as explained,
this does not mean they actually exist. Human hearing is
easily tricked and
unreliable.
Perception bias is strong. Unless you've got controls for those effects in place, any listening test is pretty much useless.
Familiarize yourself with these problems and then conduct proper, blind and level-matched ABX tests. With digital files, this is luckily trivial. If those tests still show differences, you're welcome to report back with the data. Of course, it would be much easier to just decode that level 6 compressed FLAC back to WAV and just compare it to the uncompressed WAV...
and what got me digging in the first place was because listening to the disc, in most cases, sounded better than the flacs. i'll repeat again that accurate rip checks the wav extraction NOT the final flac. and different crc's means they are differences in the final flac files.
Yes, it checks the extracted WAV. You said yourself you need to check the FLAC and members have explained why a simple CRC is insufficient for a format which does not only carry audio but also meta data. A single additional space in a song name or a different time stamp will change the CRC.
You cannot compare audio data by using CRCs on compressed files with metadata.
you can think what you want, i was just giving the op the solution i found to better sounding flac rips. if you want to take my advice or don't doesn't bother me one bit. i will link this one article and if i can find the one i was originally referencing i'll update the post.
The problem is that you were not giving a solution for "better sound", but - as it stands right now and without sufficient proof - you were unknowingly spreading misinformation. There's lots of people out there who do not understand the technical details behind stuff like audio compression and posts like yours perpetuate the silly idea that somehow, despite the fact that
the compression is 100% lossless - less compression would "sound better" somehow. Which, again,
it does not. Because it can't sound better if it's literally identical
--flac's dirty little secret
First — and briefly, don’t worry ! — some personal historical background. My journey in “computer audio” started many years ago with Logitech’s Squeezeboxes. From the very beginning, I looked for the best and more versatile file format. In those times, FLAC was not an option on Mac so I settled...
dcs.community
That source is a true gold mine! It's even got the wife in it, though sadly not from the kitchen
My wife and I, we did some listening and comparisons with AIFF and WAV files
The author claims to hear a difference on his specific DAC/streamer, which seems to include a FLAC decoder. Also, he
does not provide any evidence whatsoever that what he claims is true. He just "heard it", like all the other disproven audiophile claims. And there's ample pushback to his claims in the same thread...
