Comparing Buckeye and VTV Purifi Amps
I like my old Parasound Halo amp but also my buckeye amp. To me, the Parasound 2250v2 amp will also be transparent, same as the Hypex/Purifi amps. That's not just based on specs, but also we have blind, level matched AB compared a buckeye amp with my Halo A21 (the 2250v2 can reasonably be expected to be equally transparent) and heard no difference. So I dare say your comment "But if you're after a neutral honest sound - hypex/purifi/ice is what you want." would apply to the 2250 v2 if compared apples to apples, that is level matched, dbt, or even sbt. If sighted, okay then I have no comment.:)
I completely understand that we may have different experiences, different ears, different other components etc. So there is no actual argument here. But from what I've read parasound amps are notoriously warm. Example
In my case when I switched parasound out for hypex I immediately had to turn the sub up considerably. Not sure what that actually means though.
What you read on those kind of posts does not count because the reviewers can, and will, say whatever they perceived at the time. It has been proven in many studies that if the listeners know which gear they are using in listening tests, their preference may as well be ignored. There are probably too much to read on this topic, but try at least listening to Dr. Floyd Toole's video (free to view on Youtube), and/or read his books/articles. Based on what he, and Dr. Olive's findings, among other experts on this topic, I would say the kind of subjective opinions you linked are virtually useless except many of them are quite entertaining, and could be enjoyable to read. If you are interested, I can try to search one of those video (again, he didn't even seem to bother with amps as he often commented on that side, most can do flat FR in the audio band at very low distortions blablabla...).
Note that Dr. Toole's comments are based on speakers comparative listening, but if people are easily affected/biased in sighted tests on speakers, you can easily imagine how they can be fooled when comparing very well designed amps such as the ones we are discussing. There are nothing in the specifications and measured test results of those amps that indicate human beings can hear differences between them if used well within their designed limits. Be clear, I have no arguments with you on anything either, except the part you cited "...but from......notoriously warm..." and the linked video, and even with that, it is not directed to you, but that kind of opinions expressed in those kind of videos only. And, I am only citing Dr. Toole's comments on listening tests because you cited things you read, otherwise I really don't care what he/or others think or have said because opinions are just that, opinions, though in Dr. Toole's case, many of his comments were based on actual well conducted studies, and grounded in theories so that should carry more weight.
On the warm, musical, cool, dark, forward, layback kind of comments on amps, let alone the much more complicated AVRs, people are all over the map on their views, just read some of those Andrew Robinson kind of reviews and you may even laugh when to him, some Marantz sounded warm vs Denon's while other times he said the opposite. So, in you asked him, for sure he would tell you it's product by product, some Denon gear are warm vs Marantz cold, while in other cases it would be the opposite. Who are people to believe when dealing with such bs talks? For me, I resort to objective measurements and only read subjective measurements by the likes of Mr. Robinson's for entertainment when there is nothing else to watch on TV.
By the way, I bought my Bryston and then Parasound amp, and also acquired vintage Marantz preamp/power amps, among others, because I used to believe in subjective reviews like you do. My experience in double blind tests are very recent, for the Parasound, Bryston, vs buckeye, HK amps and for that purpose we actually purchased an amp selector and a speaker selector so we could do those tests with the ability to switch quickly, to minimize our reliance on memory.
It probably meant it has something to do with how you were doing your comparison listening tests, such as the often asked questions below:
- How were they level matched
- Were they paired with the same preamp/da
- At what spl, and were both amps driven to well below their rated output
- What speakers, impedance curve them would be especially useful in this case
- What is the lapsed time between switching from one amp to the other
- Was any tone control, room eq, rc used
When we did my comparison tests between amps, we not only level match with REW, but we actually do a sweep such as the following, that is just one of the several AB tests we have done:
In this case, if you can still hear more bass and warmth from the Parasound amp, you would have to ask, what the heck is the reason? Fortunately, we didn't feel the need to crank up the sub when using the Denon AVR lol..
Lastly, thank you for being so open minded, far too often, people who turn negative and would say something like at the end it is your ears, not the numbers etc. etc. and end any further discussion. That's very fine to me too though, because I know it is impossible to convince someone that their brain/ears do not always tell the same story to others so what they heard only apply to them, not necessarily to others, hence subjective, not facts. All the objective side can do is highlight the facts found on the test bench, and the theories related to audio amps when discussion such topics on Parasound class AB vs Hypex based amps.
what did you use for amp switching that included level matching? I know of one custom-built switch that works beautifully allowing virtually instantaneous switching of load-leveled amp output but it custom and there's only 1 of them. I'm thinking if I buy more Hypex amps I could use my minidsp to switch between presets to drive the content at pre-set output levels to two different amps but I think the switching time on the minidsp is about half a second or maybe longer.
Not included, level matching was done using REW and spl meter. We bought the amp and speakers from Amazon. I think they are the Solupeak ones.
I have minidsp flex and switching presets takes about 3-4 sec (of silence).
Wow it's great that you did all that empirical measuring. Crazy that there is no difference between D and AB designs, kinda blasphemous.
A transparent, accurate amp is transparent and accurate, no matter what the technology.
It is crazy.., but then how many people can see the difference between a 4K 60" and 8K 60" screen from 4 meters, all else being equal? If the output signal waveform is identical to the input signal waveform (except magnitude and may be phase) in the audio band, we shouldn't have to worry about the "class", but rather, other considerations such as size, weight, heat, reliability etc.
So you are saying that based on all the data and the price (I can't find them any lower priced) to get something newer. I started getting that feeling but wasn't sure. If they were $400-500, maybe but not $1000 plus! I've heard VTV's quality is pretty low - any truth to that if you know? What about building something under 200 watts from ICEpower parts at Parts Express? That seems to me to get pricy too after buying Ghent case and wiring though.
VTV have used their game in terms of build quality. Looked inside their 2ch zHypex and it looks very well laid out.
VTV is still using the EMI shielded IEC power inlet, which was not recommended by Hypex IIRC.
Lot of golden ears in this thread.
I'm jealous! My ears don't hear all these 'differences'.
VTV remains locked into the Op Amp rolling thing, which IMHO, is a total waste of money.
That's optional....you can go with the default Hypex factory buffer.
Understood, not my first amp purchase. In which case you miss out on some of the other features found in the custom buffers offered by other companies like Buckeye.
Remind me, what features do the custom buffers have?
Can confirm. Had a VTV amp for 2 years - survived multiple moves, pets, children, frequent connects/reconnects of different components - no issues at all, feels like a tank.
These seem common to most of the custom buffer offerings from many mfgrs: externally switched gain settings, soft-start/shutdown, auto sense, 12v trigger, error/clip LED, etc.
Only the switchable gain is something I would associate with a buffer. The rest are unrelated features.
Why does the Buckeye NC502MP X 8ch need 2 power cords and the similar VTV offering only has 1 cord/ one switch? If you don't turn the Buckeye amp on in a specific sequence (both amp power outlets on prior to plugging in, and the amp being triggered by 12v or auto sense), you will get a fault light? Not that you would normally do this...but if amp is in 12 volt trigger (standby but currently off) and you cycle the 2 on/off switches in the back....you will get a fault that can only be cleared by unplugging the amp, placing both amp switches to on, then plugging back in. Had fits with this when hooking up for first time.
