Hi all,
Just wanted to share an observation & perhaps get some feedback from the experienced & knowledgeable ASR members. So I purchased a second Musmys E-406 amp (
original post here) with the intention of eventually having a true vertical bi-amp setup once I upgrade my main speakers (Martin Logan ESL) to a higher-end pair like the ML Classic ESL-9.
The first one I had for about 7 months now, and has probably between 600-1,000 hours of usage. It is still working reliably & remarkably well... sounds as good as the day I got it. So, before I disconnected the cables on the back, I did one more REW in-room measurement test. Then I plugged everything on the brand-new amp, without any changes to how the cabling (DAC > preamp > amp). Then after a bit of warmup, I measured with REW. Here are the graphs:
LEFT channel = red (new) | blue (old)
LEFT channel = green (new) | yellow (old)
Definitely consistent, however the difference is I actually had to lower the preamp volume by around 3db on the new amp before taking a snapshot of the graphs. It seems the newer amp is about 3db louder than the old. So I asked AI (Gemini) if this is normal (comparing old vs new), here's Gemini's answer:
Let me know what you guys think... is what Gemini AI claiming realistic? =)
