Compact Digital Amplifier with Variable Highpass for Satellites?
DrSpan
Can you suggest any small 2.1 amplifier in the form factor direction of lets say an Smsl A50 or Dayton DTA-2.1BT2
and similar so fairly compact ,
that has an active Highpass with variable frequency for the Satellites?
Not looking for plate amps as they are all too big to carry around
I am searching among these small digital amps but its hard to find one with this feature. Mainly i see Subwoofer X-over but no mention about what happends with the Satellites
I read in the Dayton manual „Sub fX-over 50-120 hz“ but no mention of what happens with the Satellite signal.
So in a case with a variable Sub X-Over frequency ideally the Sat`s would get Highpass filtered at the corresponding frequency but i have the feeling
that most of these amps send full range signal to the Sat`s even when combined with a sub.
The luxury solution would be to have the ability of a variable Highpass frequency for the Sat`s that i can activate even without using a Sub
WiiM Amp/WiiM Amp Pro:
Crossover frequency can be set freely between 30 and 250Hz.
You can enable the crossover with no Sub connected.
There's more sub integration features like phase, level, delay, and a 10-band Parametric EQ with automatic room correction or fully manual configuration.
All adjustable from your MLP using the WiiM Home App.
The new Douk A5 amplifier does just that.
Douk A5 Budget Stereo Amplifier Review
Thanks.
The Wiim is the „luxury“ version and i have it in mind.Now hoping to get some more suggestions and maybe even smaller device recommendations
