As I recall it, cable lifters were first publicly mentioned sometime back in the late 1980s by Enid Lumley—then a reviewer for
the absolute sound—who, in an article for that magazine, claimed that, just by using short lengths of "two-by-four" spaced every few feet to lift her speaker cables off the floor, she had gotten a clear and obvious improvement to the sound of her system.
Now, however, somebody has published a video on Facebook—I'm sorry I didn't think to save it at the time, but perhaps you can find it yourself—that seems to cast a whole new light on the subject: It shows actual measurements that not only seem to prove that cable lifters
can work, but that indicate (at least part of) a real and believable reason why they
do work.
What the video shows (and that you can easily duplicate for yourself, if you wish), is a speaker cable, presumably one of a pair, lying directly on the floor ready to be hooked-up between an amplifier and a speaker system. A man is holding an LCR meter (L for Inductance; C for capacitance; R for resistance), set to read out the capacitance of the cable. To begin, he takes and calls out an initial capacitance reading with the cable still completely flat on the floor. Then he lifts part of it (about a foot [30.48 cm]) off the floor, leaving the rest in place, and takes, shows, and calls out another capacitance reading. Then another, and another, and so on—always lifting about an additional foot at a time, and always leaving something in place to hold the lifted portion of the cable off the floor—until the entire cable has been lifted, read, and called out. As he proceeds, each measurement (the total capacitance reading for the entire cable), starting from the initial one with the cable lying flat, gets lower and lower until the entire cable is off the ground.
What the test shows is that the total capacitance of the cable is not dependent just on its internal and design characteristics, but that it is also affected by its environment—in this case, either the floor upon which it rests, or the air with which it is surrounded—which becomes an effective part of its working dielectric.
Lifting the cable off the floor lowers the cable's total capacitance, which can make a difference to the sound of your system in either or both of two ways: The first way is by directly affecting the frequency response of your speakers.
from Bunking Cable Lifters, Roger Skoff
https://positive-feedback.com/audio-discourse/bunking-cable-lifters/
