Walter
- Joined
- Aug 25, 2020
- Messages
- 856
- Likes
- 1,242
I have not tried actually used headphones in at least 25 years because I never found a pair I could wear for more than 2-3 hours without pain. Over-ear models hurt my head due to my eyeglasses, and on-ear models hurt my ears. The emergence of IEMs and smartphones was a godsend for portable use, and I have a pair of the original Sennheiser CX300s that served me well for occassional use over 15 years until one of the "bodies" just popped right off the driver a few months ago as I was pulling it out from under a stack of stuff on my desk. However, I can't wear IEMs when working--I find the "in my head" sound too distracting. Knock on wood, but my business seems to finally be about to take off and I may soon need to start going into an office to manage staff. This means either silence or once again trying headphones, so I'm wondering if there are options that would truly be comfortable all day long. They will need to be closed back with good isolation so as not to annoy others sitting a couple of meters away. I'm not certain of the budget--definitely under $500, but about half that would be strongly preferable. I'm open to gaming headphones--having the microphone would be a plus, actually. I don't need the ability to play loud--85db peaks would probably be the max unless I just liked them so well that I also used them at home. Even if I don't open an office, as we get into rainy season I am realizing that the rain hitting the corrugated metal awning over the balcony outside my home office is so loud during a storm that it is impossible to hear the other person during phone calls/Zoom meetings, etc. Although if that was the only use, IEMs or open back phones would be fine. There is a very strong chance that I will have no ability to listen to anything before I buy them, or return them if I don't like them, which is one reason I want to keep the cost down.
Edit: I am thinking that I will probably just run them straight from the headphone output of my (Linux) PC, then pick up a good dongle amp like a Tempotec or E1DA if I confirm that I like using them. I do not want a desktop box. I can EQ them but not measure them, so if they need EQ it will need to be a model that has settings available or at least a reliable FR graph I can use as a starting point.
