I have a power amp (Topping PA3s) that I've been using with a bluetooth streamer (Moode on RPi with DAC Pro hat). There's a second sound source that I want to use with the amp, too. I purchased a Little Bear passive mixer so that I can switch between the two sources: channel 1 is Moode/RPi, channel 2 is the aux audio from my projector.
The problem is that the projector's volume is much lower than the RPi/Moode - so much lower than I have trouble hearing it! With the RPi/Moode, I rarely turn the amp's volume past 50% to get to a comfortable listening level. With the projector, the listening level is always too low, even with the amp's volume maxed out at 100%.
I used my oscilloscope to measure the Vp-p of the projector: it's 1V directly out of the device, which drops to ~700mA when passing through the passive mixer. For comparison, the RPi's Vp-p appears to be roughly 3.3V. (For testing the projector I used a pure sine wave signal. For the RPi I was less scientific and used music as the test signal.)
I want to boost the level of the projector's signal. I'm considering either A) swapping out the passive mixer for a different mixer or switch to reduce the voltage drop, or, B) acquire a preamp to insert before the projector's signal reaches the mixer.
I have some questions. Do all (entry level/affordable) passive mixers/switches cause the volume to drop? If not, please recommend other mixers or switches that cause a less significant drop in volume. Alternatively, I'm wondering if an active mixer would be a better solution. However I'm not sure if an active mixer is likely to introduce more noise compared to a preamp.
Thanks for any help/advice!
