Any thoughts (or references) regarding comb filtering from original sources compared to its reproduction through the chain from microphones to speakers? For example, a cymbal produces high frequencies from a fairly large object and comb filtering would occur based on its dimensions and the wavelengths being emitted. A microphone would pick up the signal from a point in space (close enough) and the speakers would produce an analog of the original emitted from a smaller object than the original.
If a listener was in a room with the cymbal, comb filtering might be perceived not only in frequency response but also in its variation with small head movements. This would be different from the sound field reproduced by speakers. Is this an audible effect, or can it be completely ignored? If the difference is audible, could the comparison be less perceptively different if the speaker had multiple tweeters, so that the sound field from the speaker contained comb filtering more similarly distributed in space compared to the original source (for some range of source sizes, at least)?
(As far as I know, the only member here who has mentioned deliberately using widely separated tweeters is @dualazmak, but I was not able to find his explanation for doing that.)
