Afraid I'm not that good at photographing household items, but here is the picture from Amazon:Hi @Ifrit, how about a few photos to entertain us with? Please...
I've had one Red Bull given to me by the RedBull rep and never had a energy drink otherwise. The RedBull was OK but not really my thang.It's like my 'energy drink' (RedBull type) in the morning and every morning.
If I attempt snoozing when I've had a coffee within maybe 8-12 hours I'm a twitching wreck that can't snooze... I don't drink a lot of coffee...I can be drinking a few demi-tasse of Turkish kahve and go to sleep in an hour.
Dang.. im going to have to get one of them.I make 1 cup of joe at a time. I use the Brew Buddy. It works great and is very portable too for camping or whatever.
https://primulaproducts.com/product/lifestyle/the-flash/coffee-brew-buddy/
It's quit rugged for what it is and has lasted me years now and shows no sign of wear. It's just for when I want one cup O' joe.Dang.. im going to have to get one of them.
Different art to getting a great coffee from one of those...Afraid I'm not that good at photographing household items, but here is the picture from Amazon:
The way I learned it is that a Ristretto is half the volume of a standard single shot of espresso.
So a Single Espresso is technically about 7-8g of coffee yielding anywhere from 21-28g in 30 sec. A full ounce is really the goal, but some shops call 21g a "shot."
A double dose is usually around 16-18g of coffee. A "triple" dose would be maxing out between 20-22g which are the largest baskets I have come across (and which makes sense assuming the single dose of coffee is 7g).
The complicated part is that traditionally, a double espresso would also yield twice as much liquid, but should still be pulled in 30 seconds. ...So a 2 ounce pull, which I have never seen in a third-wave coffee shop.
Now, enter Ristretto. Meaning restricted or narrow, as an Espresso drink, you would pull half the volume of the single shot (7-8g of coffee), commonly seen now as 14g yield in 30 seconds. The way I always learned to do this is to fine the grind to yield half the volume.
Some sources go as far as saying a Ristretto would be 1:1 ratio... Frankly, I have never seen this in practice either.
Complicating things again (further?, some more still? ) is a general misunderstanding (perhaps) of whether a Ristretto should always be a 14g yield, or if it should always be a 1:2 ratio of coffee to yield.
(If the latter, the implication is that a Double Ristretto should be a full ounce beverage at 28g from 14g of coffee.)
Thus I have detailed a complete bastardization ond likely breakdown in how we define TWO different aspects of Espresso: The DOSE (and I will come back to this) and what is RISTRETTO.
If you apply my stated parameters and previous discussion about how I arrived at those as my House Style (20g dose, 14g yield, 30 sec) you may see that I am in one manner serving a triple ristretto in that I am using a "triple" dose (20g) and yielding about 14g in 30 sec. Obviously this assumes the yield at 14g is the most important characteristic and not a particular ratio of dose to yield.
If taken the other way where a ratio is more important, then assuming a 1:2 ratio is correct, a single ristretto should be 14g, a double ristretto should be 28g...
Another complication: how do you achieve this? As mentioned earlier, I use the method of fining the grind to extract 14g in 30 sec. Other variations I have seen involve pulling a normal shot but only doing so in half the time (15 sec); pulling a normal shot but only keeping half the volume by throwing some of the shot away, or variations of these.
Now the reason behind ristretto: By only extracting such a small amount of the potential shot, you are leaving the less desired flavor characteristics behind. Usually, a proper ristretto is described more often as "sweeter" than an espresso, and often times more concentrated. Most sources agree that the more bitter compounds in coffee extract towards the end.
Fun experiment: The Rainbow. Set yourself up with 6 clear shot glasses for a 30 second pull. Pull a shot and switch glasses every 5 seconds, timing from the first drop. Look, smell, taste... Enjoy. This process allows you to dissect an espresso shot by time, so to speak. you will not only experience different flavor profiles, but they should show different coloration, too.
I have. I like it.Has anyone tried cold brewing; what do you think?
I was curious, so I ordered one of these: https://www.hario.co.uk/collections...hario-mizudashi-cold-brew-coffee-maker-red-1l
Wowowow I'm learning new analogies and stuff. RFLMAO... Gotta keep those hot Christmas trees apart or they will breed!a six ounce drink over ice could still light you up like a christmas tree in heat! (Isn't that an image! )
Best advice I can give is to remove the water from the boil, count to ten, then pour. You don't really want it right at the boil, but as with many things... If you are happy with the results then you are fine.What is the proper brew temperature for ground coffee for a simple cup of coffee? I use boiling water with my pour over rig and it tastes excellent and the automatic coffee maker has a lower temp of the water and it seems OK too? I think the boiling water method tastes better. What is the best?
Where do you live, please? Or where were you trained in the dark arts of slinging caffeine if different than where you live now?
I appreciate your post. Thank you.
I only started really drinking espresso sometime after 2008 when I started my business as a Private Chef. I did my Barista training at the end of 2019.
I had a good friend from Vienna that talked about not being able to get a good espresso here in the States.
After my time at a respectable cafe, I would almost agree with her, at least about Barista knowledge here. It’s almost as if a step is missing in our process.
The end result could still be pretty fantastic, but somewhere we lost the part about how we got here. Like so much else, everybody also wants to put their personal stamp on it too (the better cafes not so much as those a step down).
That is a beauty. The manufacturer is CopperBull. You made me look mine up:Afraid I'm not that good at photographing household items, but here is the picture from Amazon:
Anyway, one of the nicer aspects of doing cold brew is you can use up older beans! Freshness is a waste on cold brew.
You keep telling us that you are a trained barista!I absolutely disagree. Salt does not suppress bitterness by "overpowering" bitter compounds. Rather Sodium ions (and Lithium, as well) chemically block to varying effect different bitter compounds from binding to taste receptors...
Cheers!
I am not here to argue pro or con and I do have my own findings which seem to agree with the above extract but I be no barista graduate and don't have to be.The Influence of Sodium Salts on Binary Mixtures of Bitter-tasting Compounds
Abstract
In order to study potential mixture interactions among bitter compounds, selected sodium salts were added to five compounds presented either alone or as binary bitter-compound mixtures…
…For comparison, the concentration of each solitary compound was doubled to measure bitterness inhibition at the higher intensity level elicited by the mixtures. The following sodium salts were tested for bitterness inhibition: 100 mM sodium chloride (salty), 100 mM sodium gluconate (salty), 100 and 20 mM monosodium glutamate (umami), and 50 mM adenosine monophosphate disodium salt (umami). Sucrose (sweet) was also employed as a bitterness suppressor…
Introduction
Everyday life exposes us to complex mixtures of bitter tasting compounds. For example, many foods contain multiple compounds that can elicit bitterness (e.g. catechin, theophylline, theobromine, and caffeine in black tea)…
Despite the potential for interactions via the cellular complexity of the bitter taste system [multiple G-protein-coupled receptors and post-receptor transduction mechanisms…], bitterness perception often appears additive when compounds are mixed in binary combination…
There are few known bitterness inhibitors, but sodium (Na+) salts have been shown to suppress the bitterness of certain compounds in human psychophysical studies. This suppression is mainly an oral peripheral effect of ions (at the cellular/epithelial level) rather than a cognitive effect (central process) of the perceived taste.
Sodium gluconate was used in this study because of the reduced salty taste (compared to NaCl) associated with its large anion; low perceived saltiness allows us to distinguish between the peripheral inhibition of bitterness by Na + ions and the central cognitive inhibition of bitterness by perceived saltiness.
Umami-tasting Na + salts were also included in the present study because a comparison of the bitterness inhibition of several Na+ salts revealed that the umami tasting salts monosodium glutamate (MSG) and adenosine monophosphate (Na2AMP) were the most effective at inhibiting bitterness
Conclusion
The bitter taste system appears to be sensitive to the total level of activation by combinations of bitter compounds. Components of a bitter mixture appear independent—both in terms of additive taste intensity and in terms of suppression of bitter mixtures. These observations are consistent with the idea that the bitter system tracks absolute net activation by all bitter tasting compounds and that suppression of bitterness mixtures will be related to the overall levels of activation within the bitter taste rece
From <https://academic.oup.com/chemse/article/29/5/431/368354?login=false>
I have major experience with eating traditional Chinese food for a average white guy and they have dishes that are based exclusively on bitterness. I mean bitter bitter weird exotic veggies and meat dishes that are dolloped onto rice and the combO is awesome. After the first 2 or 4 bites it becomes addictive and one must have more. Bitter is a flavor that is intentional by Chinese chefs and I am happy they do it.I am venturing to guess that the middle B is the most detested of all tastes.
Starbucks should be able to monetize that preference as their coffee is sooo bitter that I became a DIYer!I have major experience with eating traditional Chinese food for a average white guy and they have dishes that are based exclusively on bitterness. I mean bitter bitter weird exotic veggies and meat dishes that are dolloped onto rice and the combO is awesome. After the first 2 or 4 bites it becomes addictive and one must have more. Bitter is a flavor that is intentional by Chinese chefs and I am happy they do it.
Lol... I am a Starbucks aficionado for their dark roast. I crave it and never am able to make it at home like they do it. Nearly every morning I make my way to the mall and get a vente dark roast and peeps here tell me that is burnt bean and it's horrible. Soooo... I am going to try the Pikes place and the Blonde and as a added benefit they have more caffeine. A vente size seems about just right before I get all twitchy and feel weird from overdosing on the caffeine. I get a buzz and tightness in my cheeks and that's when I know I am approaching the max limit.Starbucks should be able to monetize that preference as their coffee is sooo bitter that I became a DIYer!
