We'd need a conversion factor between North American brown dishwater and espresso to evaluate.That's a lot of coffee mate.
Well, yes.Surely you’re joking, Shirley!
Hmm... this conversion makes an almost certainly incorrect assumption: that the extraction rate and TDS are the same between the brewing methods. Grind size, water temperature, and brew time are the deciding factors in coffee strength. The amount of coffee grounds in grams is the only metric we can really go on here.Well, yes.
But it does call for science* so let's see. A Kuerig k-cup** has 9-12 grams of coffee apparently, roughly half an E61 espresso double shot that most of us*** use to make a ~42 ml cup. A 12-oz cup/mug is 340-355 ml (accounting for any transatlanticism****) so around 8 times more water. Or 16 times less coffee by volume.
So 4-5 of those mugs are 2-3 espresso. That would be an average day for me. Different results for different Kuerig pods however. They reckon up to 26 grams, which would mean 5-6 espresso, thus approaching 'a lot of coffee'.
*using the term loosely, as is the custom
**whatever that means
***espresso machine tragics
****gratuitous Death Cab for Cutie reference
The coloured plastic versions are safe to use, and better at heat retention, which is important when brewing light roasts, the clear plastic one cracks with boiling water, avoid it. Alternatively just buy the version you like the look of best.Has anyone a preference for the plastic vs. ceramic V60 funnel? My assumption is that plastic may leach harmful chemicals at high heat. I use the ceramic V60, and feel the wet&wait pour will heat up the funnel.
Being unfamiliar with Keurig, I assumed it was a Nespresso equivalent (and steve59 was drinking Americano or Lungo). So it's more like a capsule-fed drip machine?Hmm... this conversion makes an almost certainly incorrect assumption: that the extraction rate and TDS are the same between the brewing methods. Grind size, water temperature, and brew time are the deciding factors in coffee strength. The amount of coffee grounds in grams is the only metric we can really go on here.
If you're measuring strength by the energy boost, then a cup of drip coffee will have more caffeine than an espresso despite using less ground coffee. Figure 15-18g for espresso and 12g for drip. Caffeine isn't particularly soluble in water and requires time more than anything else. That's why cold brew is so powerful.
Well, good news is espresso can be made with any coffee you like. It's a brewing method, not a roast. But yeah, barely-lighter-than-charcoal "espresso roast" is bad.Espresso? Not for me. I have tried it, but anything that taste remotely like a dark roast makes me feel sick. Never understood how burnt can be associated with good tasting. I have tried to like a dark roast, I really have but I find it wretched.
You're right- Starbucks does their dark roast to keep consistent flavors from batch to batch even when the beans change drastically. They tend to go well beyond the second crack.My understanding is that the prevalence of very dark roasts in the U.S. was driven primarily by Starbucks: dark roast makes for a strong, albeit bitter, cup of coffee, and dark roasts remove some of the distinctive flavors of the various kinds and batches of beans. So for Starbucks dark roasts have been a way to both distinguish themselves from the weak, watery coffee frequently served by independent diners and sidewalk food carts around the country, while also allowing for more consistent (though, again, over-roasted and bitter) taste across their 1000s of stores. It's basically the coffee equivalent of fast food.
Also, weak coffee can also taste bitter, so the bitterness of the stronger flavor of Starbucks might be something many coffee drinkers don't object to because they think bitterness is just part of the coffee experience.
Very true, my bad for making that false equivalency between the roast and espresso. I think that because an espresso is typically very concentrated that it truly doesn't matter for me what bean is used I do not at all like the product. I say that knowing there is room for error as I have not bothered with many attempts as probably after the first three or so times I completely abandoned even trying. Just not for me at all.Well, good news is espresso can be made with any coffee you like. It's a brewing method, not a roast. But yeah, barely-lighter-than-charcoal "espresso roast" is bad.
Yep, though interestingly enough the guy who founded Starbucks completely misread how Italian coffee is roasted. It's not usually super dark. It's usually medium to medium-dark (at least for northern Italian coffee), but has some Robusta mixed in for flavor and crema reasons.My understanding is that the prevalence of very dark roasts in the U.S. was driven primarily by Starbucks: dark roast makes for a strong, albeit bitter, cup of coffee, and dark roasts remove some of the distinctive flavors of the various kinds and batches of beans. So for Starbucks dark roasts have been a way to both distinguish themselves from the weak, watery coffee frequently served by independent diners and sidewalk food carts around the country, while also allowing for more consistent (though, again, over-roasted and bitter) taste across their 1000s of stores. It's basically the coffee equivalent of fast food.
Espresso is very tricky. I went through a lot of coffee before I got drinkable shots. I still generally mix them with milk.Very true, my bad for making that false equivalency between the roast and espresso. I think that because an espresso is typically very concentrated that it truly doesn't matter for me what bean is used I do not at all like the product. I say that knowing there is room for error as I have not bothered with many attempts as probably after the first three or so times I completely abandoned even trying. Just not for me at all.
I do like a double shot americano tall though.
French roast is super super dark. I'm not into light roast coffee either, but generally if a coffee is oily it's too dark for me. I'm firmly a medium roast type.The bag of beans I'm working through now is called "French Roast" and it's very dark. I guess I don't mind that. I don't like the acidy flavor of light roasts, at least the one's I've had. Maybe that's a reaction to too many years of Folgers run through a Mr. Coffee and then left to sit for six hours.
Rick "but weak dark is worse than strong dark" Denney
I remember when Netscape Navigator was a thing. I used to design websites and it was always a pain in the ass on Navigator as it rarely implemented things such as Cascading Style Sheets (or even standard HTML for that matter) properly. Back in the day when you had to have java script detect the browser being used and serve the appropriate site. I still miss Netscape though - great logo.
I used to have a copy of Netscacpe, 4.0, I think, just for checking sites.I remember when Netscape Navigator was a thing. I used to design websites and it was always a pain in the ass on Navigator as it rarely implemented things such as Cascading Style Sheets (or even standard HTML for that matter) properly. Back in the day when you had to have java script detect the browser being used and serve the appropriate site. I still miss Netscape though - great logo.
Reminds me of ArsTechnica Battlefront in the good olde days: Apple is doomed I tell you, doomed.I used to have a copy of Netscacpe, 4.0, I think, just for checking sites.
I now have an iPhone for a similar reason.
Here's hoping that Apple goes the same way as Netscape, I'tll make my job a lot easier.
