RexrothPigeon
- Joined
- Mar 21, 2025
- Messages
- 1,687
- Likes
- 3,543
One of these will change the way you think about coffee.
Surprised you don’t like them. Certainly not a commercial grade machine or a process where I’m spending 20 minutes understanding chemistry to make a traveler cup on my way to work. But a clear upgrade to Kuerig pods. The machine is easily cleaned and gives me a pretty solid cup compared to Starbucks. Does it compare to a cup I’ve had in Tuscany where I’ve had an hour to relax and take in the surroundings? No. But for a daily drinker I’d give it a nod over your Mr coffee.It sure would, but not for the better
Low bar, but sureBut a clear upgrade to Kuerig pods.
Hope no one gets the idea that you can do the same with their music.Used to have a massive coffee setup. Switched to caffeine pills. Liberating.
I just put the score under my pillow at night and enjoy music osmotically. Life is about optimization, as we all know.Hope no one gets the idea that you can do the same with their music.
I did not buy niche. Was very extraordinarily almost mere nanometers (one could even say I was an RCH) away from buying the niche zero, but opted for the switch to Mazzer burrs on my DF83V.Hope no one gets the idea that you can do the same with their music.
We look forward to our morning espresso regimen; using a LaPavoni/Stradivari and a Niche/Duo.
Both of our palettes agree that Ethiopian Yirgacheffe (medium roast) is our benchmark.
@ryanosaur:
1) What did you do for your Niche/Uno' noise problem?
2) Does your Niche adjustment-dial walk, when it is grinding? Mine does so (ever so-slowly) and the factory has no fix apparently, just stupid ideas.
3) Have you gotten one of those bellows for it? It works beyond "zero retention"...![]()
not ryanosaur, but my NZ was fine with noise. not quiet yes but pleasant low pitch grinding sound. I like that more so than my LCHope no one gets the idea that you can do the same with their music.
@ryanosaur:
I had one for a few years before i got my ek, and no it didn't dial-walk at all2) Does your Niche adjustment-dial walk, when it is grinding? Mine does so (ever so-slowly) and the factory has no fix apparently, just stupid ideas.
This is the easiest game of "spot the difference" ever.![]()
