Coffee - do you and how do you consume it?
georgeT
Romania
Threre's more than BPA. They have a spectrometric analys of water pre and post boiling?.
I had the same worries before I bought my Aeropress but looks like it's safe "Polypropylene is a nonpolar, chemically inert material"
SIY
Alfred, NY
Except... BPA is a relatively wimpy endocrine mimic. The binding affinity to the estrogen receptor is rather low. Materials which have been used as a substitute are often worse endocrine disruptors than BPA, but don't have that recognizable three letter acronym. In the case of polypropylene, it's the antioxidants and process aids used which can be strong xenoestrogens. So changing out plastic types will generally not change the exposure, it will merely change the specific estrogen mimic. Sorry to break the bad news.:cool:
Here's a chart of estrogenic activity in some plastic beverage products, baby bottles and water bottles (polycarbonate being the principal plastic that uses BPA).
The good news is that unless you're a baby or small child or a pregnant woman, there's no good evidence that the effects of estrogen mimics are particularly significant.
Back to coffee.
Helicopter
Michigan
Back to coffee.
I am more concerned about paper filters removing good stuff from the coffee, but my primitive DIY cold brew setup is all glass and steel unless I grind in my plastic blender jar.
wasnotwasnotwas
Nespresso for espresso /cappuccino (usually the arpeggio purple cap). Did have "proper" espresso machine and grinder but too faffy and inconsistent and time consuming for daily use (needs 5 to 10 mins before you can brew) so Nespresso ftw.
Aeropress using Pact coffee mail order ground (great in the UK) for everything after the Nespresso or if in the office.
Soniclife
I didn't know this. I'll have to look into it.
All paper filters remove some of the oils, which is personal preference for taste. The aeropress filters being very small, and the water forced through it when you push probably remove the least. You can get permanent metal disks, if you want to try that out.
Soniclife
Looks like there are two distinct schools, the expressos and the long coffees (is there a better name?), quite surprised. I am in the former but quite interested the Aeropress..
The general term for long coffee is brewed coffee, same usage of the word as with tea.
wasnotwasnotwas
I find the metal discs work well and easier (and hopefully greener) than the paper filters.
Soniclife
this is even worse than an audio hobby.
It's very similar, lots of sighted subjective opinions, some blind testing, a million gadgets, not enough real science on preference, a surprising amount to learn. On the plus side lots of coffee gadgets are cheap, and do make a difference, plus coffee and music are a good combination.
Duckeenie
I see a lot of fancy gadgets these days that make expensive lousy tasting coffee. My preferred tool is still a stove top espresso maker.
Cortes
Cigars! is missing item here ;-)
Duckeenie
Great thread.
I am what you would call an avid consumer of coffee. :cool:
I use a cheap generic Krupps coffee maker and fresh-ground beans of various types and brands. They don’t seem to make the exact model of coffee maker I use anymore but it’s the same design as the current Krupps coffee makers, just as stripped down in terms of features as you could possibly imagine. So I think it cost $25 or $30.
I drink 6 to 12 cups of fresh brewed coffee a day, black. I would be interested to know if anyone else drinks that much. :D
I used to pop into coffee shops for a kicker but coronavirus changed all that. :oops:
I drink around 6 cups a day but I stick to decaf, lest I need a trip to my nearest A&E dept.
Cortes
Also, I guess this is common to all human activities lacking a mindset for scientific methodology. For instance, I take my kid to Suzuki classes of violin. I do that for a host of reasons, but not for the methodology. Suzuki method sounds all logic, all structured, all natural; I'm sure is pure garbage, there is nothing serious backing it.
A Surfer
Teflon (polytetrafluoroethylene) in its finished form is extremely stable (and non-toxic) at temperatures below about 250 °C, so it's perfectly safe in normal cooking. The manufacturing process may involve the use of perfluorooctanoic acid, which can be harmful to health, though its use has been phased out. If you already have teflon cookware, I wouldn't worry about continuing to use it.
Not so. The chemical compound that underpins Teflon is man-made and does not occur in nature. Now due to the release of it through industrial processes it is so ubiquitous that they find it in the blood of Polar Bears and in umbilical chord blood. The notion of stability ignores so many other routes of release. Research it, is scary. I once found a wonderful article about the workers exposures at a factory where Teflon was being made, it was very eye opening.
I know that they have recently come up with supposed safer alternatives, but safer according to who? Don't forget, much of the world uses hazard ratings in other words setting "safe" limits for toxin exposure which means limits written by industry deciding how much should be ok in our blood and organs. The EU has tended towards the precautionary principle where the onus is on companies to demonstrate that something is safe whereas in good old North America where only money matters, we don't ask companies to prove it is safe, our regulators work to set safe exposure limits which is so complex.
The real issues are bioaccumulation and interaction effects, those are not part of risk of hazard levels, they simply look at acute dosages and ignore chronic bioaccumulation. There was a wonderful graph that I found where a researcher used the time line starting with the chemical revolution in the 1950s and overlaid the change in cancer rates, the trend lines were almost a perfect match. Of course there would be confounding factors, but it was too close to be explained away so simply. Anyway, no, those crazy industrial anti-stick coatings are not benign and they do get into our bodies and the environment.
A Surfer
Back to coffee.
Lots of babies, pregnant women and amphibians to be concerned about, but yes, back to coffee.
StevenEleven
After a brief look around the web it seems to me the Suzuki method got some things extremely right—treating music as a language and hitting it in the formative years for language, getting kids started early (can be crucial), progressing in non-intimidating increments, creating an immersive musical environment, accommodating younger minds and smaller bodies. :)
My son used some Suzuki books for the cello. It seems to me it is “a way“ to learn music. There are all sorts of tensions and trade-offs in exactly how one pursues learning music. For my kids my objective was always to make it fun and have in mind that it could be a lifelong pursuit, and it was for them rather than me, and they don’t have to be great at it. Two of the three are still playing and the third can sightread on the first go at a level that takes me at least two or three hours of practice (I am currently hell-bent on practicing sight-reading to catch up to him on this). The thing about learning how to play music is that it illustrates very tangibly the benefits of putting in the effort, which transfers over to so many other things in life, and it does alter how the mind processes information (fMRIs seem to confirm this).
But Suzuki theory seems to me to be a bit optimistic in terms of objectives of moral character, the beautiful life, improvement of society, etc.?
Back to my coffee and my daily piano practice (I’m not very good but will never give up until they put me in my grave). ;) The former must precede the latter.
mansr
Hampshire
Playing the violin while riding a motorbike doesn't seem very safe.
mansr
Hampshire
That would be the perfluorooctanoic acid.
Count Arthur
Well worth a watch: https://en.wikipedia.org/wiki/Dark_Waters_(2019_film)
I now use a seasoned cast iron pan for cooking. :)
