Hello,
I'm seeking for a closed/sealed subwoofer.
It'll be used in a small dining/living room (20sqm) in an appartment, for both homecinema and music.
This context means that the max SPL or distorsion at high volume are not a criteria for me. Indeed, might have to restrain the volume to save the relationship with my neighbors!
My AVR (Anthem MRX 520) has a good calibration system, so I guess and embedded EQ is not a criterion either.
(Plus ARC might help me to compensate for the bass perception at low volume by tweaking a bit the gains.)
I'm seeking for very 'tight' bass, so with my limited understanding I guess it means:
- closed architecture
- low mobile mass
- strong motor/driver
Budget is around 700EUR.
Second hand is okay.
I'm open to different configuration (e.g. two less expensive subwoofer to compensate for room mode instead of one).
Many thanks!
Fred
- low mobile mass
Many thanks!
Fred
