D
Deleted member 77856
Guest
Yes like champagne or caviar.This thread is about closed back < 500.
Ultrasone is well... an acquired taste.
Scotch or cigars.
So much for the processor for the cheep cell phone he's using. Goes well with the knock off pseudo Hawaiian shirt
The best review Tyll ever did ...
Definitely!The best review Tyll ever did ...
DAP may also refer to a company that sells products such as sealants and spackling compounds.You mean that expensive DAP he hooked up to an amp ?
Definitely a contender, so is AA Hi-X60Well since we're talking about closed back headphones under 500 what about AKG? K553 MKII
I am not a gamer but HD620S is closer to HD560S. Sennheiser support is well known. FT1 does not even sell parts like pads. HD620S is 2x more expensive.@solderdude How is sound-stage and imaging HD620S vs FT1. Which of those gonna be closer to HD560S in performance for Gaming. Want something in closed back which is good for gaming and also has long term reliability unlike Maxwell. Looking for wired headphones. Not wireless.
Cool but overall Soundstage and imaging. Which is superior as per your testing. Which is more spacious and provides accurate representation of placement of objects or instruments in music. Even based on Music testing which is better performing in those aspects.I am not a gamer but HD620S is closer to HD560S. Sennheiser support is well known. FT1 does not even sell parts like pads. HD620S is 2x more expensive.
www.audiosciencereview.com
Clearly you haven't taken your girlfriend out to shop for "marital aids"... Nothing as personal as a headphone
Alas they do not exist.I want headphones that impart no color and just accurately represents what is being played. It is OK to need eq to do this, as my Wiim Pro has one, but I would prefer something that needs as little of it as possible.
I’d add the new Sony MDR-M1 to the list. Also @solderdude , I hope you review those soon!Alas they do not exist.
The reason for this is what person A considers 'not colored' may be substantially different from what person B or C considers 'not colored'.
When determining this based on measurements one has to pick a measurement standard of choice and target curve for that standard and then you can pick headphones that follow that standard the closest.
This, however, is not guaranteed to sound 'without color' to you at the listening levels you prefer and or the seal you might be able to get (or not).
All the mentioned headphones have some coloration you might like or not but all are decently neutral in some ways.
When basing the choice on measurements you would need to figure out what tonal balance fits the various target curves that exist.
Only AKG 371, HD 620s, and the Drop _ DAn Clark Audio Aeon X Closed are closed. You could add the FiiO FT1 if you like lightly elevated lows (fine when listening at low SPL or while commuting) or the SRH-840A. When you have small ears that are not protruding or don't mind if your pinnae are touching the drivers the MDR-7506 is an option.
Don't forget to put the Austrian Audio Hi-X60 on your list either.
Note: most closed headphones are very seal dependent so when using glasses or having hair between the pads and head bass might be compromised.
This effect is usually much less with open headphone unless they have really good low bass extension.
One thing I think will happen and I can see / hear this a little of this already with the new AirPods 4, is that ANC headphones will get much smarter. Specifically, I noticed 2 things that Apple are doing (and no doubt other companies are also thinking about):Alas they do not exist.
