I listen to all kinds of classical and more generally acoustic music: from medieval, renaissance, baroque, classical, romantic. My interest fades around 1900 when this music stopped sounding like music to me (with a few exceptions like Rachmaninoff and to a lesser extent others like Shostakovich). I prefer small ensemble works. I've got a mix of some of the best historical performances from musicians like Heifetz, DuPre, Ashkenazy, and some modern versions like Florestan, Emerson, Belcea. For example I enjoy listening to first Berman (1963), then Gerstein (2015), play the Liszt etudes. Or whatever. I also listen to ancient and traditional music, anything from Hildegard of Bingen to Joel Fredericksen to Brian Kay or even the Chieftans. Also a variety of jazz, from old classics like Coltrane, Brubeck, etc. to modern like Diana Krall, Yuko Mabuchi and Fonnesbaek.
Anyway, I'm looking for guides & reviews to expand my collection. I don't think I'll ever like modern classical music, and I'm not even going to try. So it's more about discovering either (A) new composers or musicians in the genres I like, or (B) new modern performances of these pieces that have something new to say.
I've read Grammophon, Fanfare, BBC. They're OK but not really what I'm looking for. Either too narrowly focused, too snooty, or for whatever reason occasionally useful but overall just not my cup of tea. I also follow Stereophile's "Records to Die For" which has occasional gems. Any other recommendations? What publications do you subscribe to, or otherwise how do you discover new music and performances worth having?
BTW the title says "Classical" but this is open to pretty much any kind of acoustic or mostly acoustic music.
I don't know about finding *recordings* per se (I just use spotify or the label's website "preview" function to make a best guess before I buy the recording), but I myself have found three principal ways of discovering new material with a better than even chance of liking it, or at least being interested in it.
The first, and what used to be (for me) the easiest, was the "filler" works the record labels would put in to fill up the disc to 75 minutes or whatever it was for a compact disc. So you'd get, e.g. Smith's Symphony No. 2 as the "headline" work and Jones' Sinfonietta like the supporting act.
The second has been to find a younger (really just less prolific) performer I like, and listen to some of their other recordings. Obviously if you only really like Ashkenazy, then this is not going to narrow the field very much given he recorded everything ever written a bahzillion times. But it works for younger/less prolific performers. I know the label makes a lot of the recording decisions, but from what I can gather, the performer also has quite a bit of input.
The third is to follow links between composers/performers. For instance, if you liked someone who studied under Boulanger, maybe you'd like someone else who did? Or perhaps a composer you liked might have been a champion of someone else's music, or to have written about their music in their correspondence? For instance, Dave Brubeck might lead you via Millhaud to Pierre-Max Dubois. The great thing about the internet is you no longer need Grove's or something like that to trace out many of these connexions.
Another way which might be apposite for your tastes is to look at things like the Prix de Rome and other honours. Sure plenty of non-entities won, but some pretty good composers did, and many more entered but didn't win.
If you like *classical* classical music (like Telemann & al), then there was a wireless programme which surely must be on the internet somewhere, called "Adventures in music", by a gentleman called Karl Haas. I personally don't much enjoy music between about 1720 and 1850, and a fair bit of the music he played was of the sort "You'll all know this: it's attributed to the page-turner of the guy who Carl Philipp Emmanuel Bach once met when having his carriage upholstery re-done after the great heatwave of 1763 but the autograph MS was lost in the early C19th". *BUT* his enthusiasm, knowledge, and happiness in sharing both meant I listened to the programme almost every day for over a decade (I moved then to a flat which didn't get FM very well).
All of the above go toward finding music by and for yourself. But it's also nice (if you can; it hasn't always been possible for me) to find new (new to you, not Stockhausen or even more avant garde stuff
music with a friend with overlapping but not too similar tastes. When you listen to music together with someone, they learn your taste in ways that enable them to send you "off cuts" of things they themselves didn't like, but you might (and vice versa): that's how I found Jehan Alain, whom I really like. More importantly, you get the pleasure of discovering new things with someone else (even if that discovery is "God, this sounds like a bunch of boxers beating up a wind quintet!".
The problem I have with reviews, per se, is that we don't have a general vocabulary to describe things in a consistent way (which is how I discovered this forum). Music being completely abstract, this is understandable, but I find music reviews (from someone whose taste I don't know intimately) are like (but not as bad as) wine reviews. If I went out and was given a glass of wine that *actually* had "tobacco" or "petrol" overtones (a reasonably common description, at least 10-15 years ago), I'd punch the sommelier, sue the restaurant, and burn down the vineyard (and I used to smoke like Joan of Arc). I find it much easier in the case of music just to listen on the internet (I used to use the library listening room for similar purposes) and then stump up the cash after trying a few versions. For wine, I just stick with what I know 80% of the time, but missing out on a particular vintage from a particular winemaker is not the same kind of opportunity cost as never hearing the work of [Insert a second or third class/obscure composer whom you happen to really enjoy].
