spendormania
- Joined
- Jan 26, 2021
- Messages
- 7
- Likes
- 5
Hi. This is the documentation of a two way monitor. A cardioid subwoofer will be added later.
The bass is a Wavecor WF182BD_11:
The tweeter is a Satori TW29DN put into a Monacor waveguide:
Let's start with the enclosure. After beeing 25 years a satisfied user of a Spendor BC1 mk3 and the succesful built of a LS3/5 clone I decided to go with a BBC-like enclosure.
Here's a pic of a stripped Spendor BC1 mk3:
The main ingridiences of those classic enclosures are thin but highly damped walls, beechstrips and the omission of further bracing.
So i started with the cutting of the strips.
After that, i put Alubutyl on the walls, three layers with 2,1 mm.
Every wall got an additional 2mm HDF plate and 10 mm felt acoustic damping layer.
First step was drilling of the Neutrik connectors hole and the mounting of cover and bottom.
An unexpected guest was interested in the work too ;-).
Glueing of the front strips was next, then the side walls were applied.
to be continued.
to be continued.
