Classic Audio MC Pro Phonostage Review
Rate this phono stage:
    Votes: 7 2.9%
    Votes: 8 3.3%
    Votes: 56 23.4%
    Votes: 168 70.3%
Hoping that Amir gets one of the first run to review!
That would make things a bit too hectic! I'm secretly dragging my heels just enjoying the peace and quiet.
Understood. Demand pouring in before you are ready may not be the best business decision.
Yet still, we are audio enthusiasts who are enthusiastic about your next product!
Ready when you are!
Reactions: EJ3
I see 100 pF for the input of the new LO PRO, have you also the value for the MC PRO? I cannot see in the manual or website. Thanks!
From the LO PRO manual:
The input loading seen by the cartridge is fixed at 150Ω // 100pF. This combination is designed to over-damp inductive resonances in the 1-10 MHz region of all LOMCs currently on the market, without introducing any significant response variations in the audio band.
The equivalent input noise voltage of the LO PRO is not significantly greater than the thermal noise generated by a 15Ω resistance. As a result, the common 1:10 cartridge-to-input resistance matching rule (intended to reduce the effect of insertion loss on signal-to-noise ratio) no longer applies once cartridge coil resistance exceeds 15Ω, since the cartridge’s own thermal noise dominates. The LO PRO can therefore be used without penalty with LOMCs having coil resistances up to 50Ω.
From the MC PRO manual:
The MC input loading is fixed at 120Ω//800pF, which provides the best trade-off between insertion loss and the absorption of radio frequency interference. After a brief period of research, it was found to be unnecessary to make this variable. It can be reduced below this value using loading cables, but there isn’t any benefit to be had other than pulling the level at the sensitive input down and degrading signal to noise ratio. Speculatively, it’s only popular because it can be implemented with almost no electronics knowledge...
Thanks, oops it was in the last page of the manual. :-) Which is the idea behind the lowering of the capacitance figure?
The idea with this one is that the input RF filtering is accomplished by a proper multi-pole network with impedance equalisation on the entry point, rather than relying on the cartridge inductance and just a shunt capacitance. The input capacitance is just 100pF of shunt, to pull out the worst UHF stuff and make sure the cartridge inductance isn't just left open.
Good to see you managed to start production with SMD-technology, another milestone for you company! Congratulations Michael!
These are starting to come in thick and fast now!
It's sometimes useful for potential maintenance to have checkpoints present on this...right?
(with voltage readings, etc.) ;-)
A few points on the power supply have labels, but generally with this kind of op-amp circuitry where you have two supply rails, everything is referenced to zero, so there's not much point.
We're finally starting scale production on the new version of this in Łódź, Poland (bit of a long story, but I can elaborate if necessary!), but we made the first two units for the new company today.
We're battling chaos with metal finishing treatment. As you can see, the front panels and extruded pieces have a kind of graphite/aerospace colour, while the rear panels are deep satin black. Hopefully, a move to powder coating will fix these issues for good and give us some more interesting finish styles, but for the mean time these will go for the same price as the original MC PRO did at the point of discontinuation when we start selling in October.
I kept this one a bit quiet for a year, but the measurements are really superb. A lot of tolerance averaging in component arrays on the boards tightens thing up a great deal compared to THT.
That reminds me, I still need to write a design philosophy/development history article for the MC PRO :)
