Classic Audio MC Pro Phonostage Review
Rate this phono stage:
    Votes: 7 3.0%
    Votes: 8 3.4%
    Votes: 55 23.6%
    Votes: 163 70.0%
My Panasonic SL-N15 (same as Technics SL-N3) runs the ground over the left (or right, I don't know, could be both) signal return, perfectly silent.
TVS + polyfuse on the input side, shunt diodes across first caps in the voltage-doubler "but how does my 24V AC Rega power adaptor SOUND with this unit". Usually I can "best of luck with your next choice" those guys before it comes to payment, but occasionally one will get through, or some predatory little reptile (almost always in the UK) will try and foist some dubious 'upgrade' upon them that results in destruction + it's still remotely possible to connect the wrong power adaptor by accident.
Also, strong RF filters on input and output. I designed the original to withstand about 5 times what you might expect from marginal EMC-passing equipment in the near vicinity, but it's still not quite enough for about 3% of cases, especially using exotic cartridges of the very low output type. In close enough proximity (60cm or so), dodgy LED lights from Aliexpress and ethernet-over-power adapters can yield enough RF at the input to provoke detection, especially if exotic cables are being used. Having a massively high gain doesn't help much, either. This does also affect the vast majority of contemporary preamps, but it would be good to make it much more resilient.
It would be good if we quite importing dodgy anything from anywhere. The fact that it gets through to us is what keeps people making the dodgy anything's anyway.
If they couldn't sell mass quantities of it to unsuspecting people, it wouldn't be worth it to them to make it to begin with.
But: that's a separate conversation.
Unfortunately it has an effect on this conversation: And it needn't be so.
Forgive me if I don't interpret this charitably :facepalm:. The internet is littered with furious forum users and people who've tried the product and have given ample feedback that the company needs to change its ways. Personally, when I've dealt with clients who have Rega setups, it causes an issue half of the time, all for a tiny little wire...
Rega: Just say anything, make anything up, say you've changed the electrical alignment of the design or some other BS, but fit the ground wire!
Regrettably, Fidelity Research FR 24S was guilty of this in the past as well - lovely arm, impossible to find cable, and no ground wire...
My advice (unsolicited), would be not to change anything in the setup if you're not experiencing any issues.
Indeed, but it does pose an interesting design challenge, and also a market advantage if the problem can be solved in some way that doesn't require brute force/hideous compromises.
Reactions: EJ3
Some were fitted with DIN connectors - I’m guessing later in production. They are harder to find.
I don't know enough about Fidelity arms to be able to name which was which, certainly the FR-54, or the FR-64 came with 5-pin DIN Style connectors. The 24S cable with the threaded connector can be an expensive afterthought, if one would find a nice example that's missing the original cable.
Yes, most FR-24S have the strange connector but there are some specimens out there with a DIN connector. Unfortunately, they are less common. I have owned 3 FR-24S, and I believe only one had it. All later FR arms did, AFAIK.
The subsonic filter deals with cutting out tone-arm resonances/record warps/surface effects below 20Hz, while the LF XFEED function reduces stereo field noise below 100Hz or so. They both do different things: one operates outside the audio band, the other within it.
Michael, what's your view on filters for reducing LP noises including pops and scratches and hiss? There are one or two phono stages that attempt this. I can't help but feel that they will fail to avoid any deleterious impact on the music signal.
While noise reduction, especially impulse noise reduction, can be very effective for restoration, it's very difficult to implement this to a satisfactory degree for general playback.
Wideband noise reduction (hiss) can create unpleasant artefacts, and the threshold point is nigh on impossible to set correctly on the fly. For discs in restoration, the thresholds can be tuned, and the level of reduction modified to mask artefact, but for direct playback it's pretty bad. If the threshold is too low, a lot of watery artefacts are generated by granular nosie.
Impulse noise reduction, click detection and interpolation, is generally much better, although it is still important to set the threshold of detection high enough so that certain recorded waveforms and transients do not trigger false positive and hence distortion. For a very high detection threshold, it can certainly work with DSP, but will only be able to remove the worst clicks. There are also questions of overload margin that come into play when DSP is implemented.
I own a few thousand 78s, and find limiting the bandwidth to be most useful for playback/off-disc listening. Switching to mono also greatly helps.
Could I respectfully suggest that this test / thread is moved to join most of the other phono amplifier reviews in the Turntables, Phono Amplifier, Cartridges Review forum?
I noticed this review (and maybe a few others) was missing from the phono preamps comparison chart.
This is because we are talking about an MC input: all of those measured devices are MM, and there is yet to appear a graph that compiles the results of MC phono preamplifiers.
........ there is yet to appear a graph that compiles the results of MC phono preamplifiers.
I was thinking of putting one together myself, it would show the MC Pro in a very good light.
Phono preamps have varying gains, but I noticed a pattern. If you add gain + SNR a good head amp gives you around 120dB no-matter what sort.
It doesn't vary enormously, so it's quite a good figure of merit. The MC Pro stands clear of the rest though - at 140dB - but it takes some digging.
I have a Luxman PD300, Alphason HR100S and AT OC7, so definitely need an MC head-amp (preferably with balanced output, though not sure if I can buy one any more).
Here we go, arranged in order of MC SINAD+gain, then MM SINAD+gain:
Brand
ModelPrice
USD
SINADGAINTOTSINADGAINTOTRec'dReview
Date
Review
Link
MMMMMMMCMCMC
Classic AudioMC Pro$850
73​
69​
142​
Yes8/13/23Review Link
eXemplar AudioException Phono$6,950
64​
43​
107​
54​
73​
127​
No3/25/19Review Link
SOTAPyxi$300
80​
46​
126​
65​
59​
124​
Yes5/27/23Review Link
Cambridge AudioAlva Duo$300
84​
39​
123​
63​
60​
123​
Yes7/24/23Review Link
SchiitSkoll$399
81​
41​
122​
64​
59​
123​
Yes10/14/23Review Link
ParasoundZphono$200
76​
47​
123​
56​
59​
115​
Yes09/08/20Review Link
ART Pro AudioPrecision Phono Pre$81
78​
34​
112​
60​
52​
112​
Yes6/13/22Review Link
PS AudioStellar$2,499
65​
44​
109​
51​
61​
112​
Yes9/24/21Review Link
VincentPHO-8$250
73​
40​
113​
51​
58​
109​
No3/25/20Review Link
Graham SleeReflex C$900
0​
59​
50​
109​
No01/09/21Review Link
Six AcousticsYork$437
67​
40​
107​
48​
60​
108​
No04/12/22Review Link
Cambridge AudioAlva Solo$180
86​
39​
125​
0​
No11/01/19Review Link
SchiitMani 2$149
81​
44​
125​
0​
Yes2/23/22Review Link
Emotiva AudioXPS-1$200
82​
42​
124​
0​
Yes5/16/19Review Link
Musical FidelityMX-VYNL$1,000
79​
42​
121​
0​
Yes06/07/19Review Link
Pro-Ject Audio SystemsPhono Box DS2 USB$600
80​
40​
120​
0​
Yes07/12/20Review Link
RegaFono Mk3$400
78​
41​
119​
0​
No11/04/20Review Link
U-Turn AudioPluto 2$99
78​
40​
118​
0​
Yes6/23/21Review Link
SchiitMani$130
74​
43​
117​
0​
Yes07/11/19Review Link
U-Turn AudioPluto$100
80​
36​
116​
0​
No06/10/18Review Link
Pro-Ject Audio SystemsPhono Box MM$89
76​
40​
116​
0​
No07/08/23Review Link
Rek O Kut UltraUltra$159
76​
39​
115​
0​
No5/17/22Review Link
Hagerman Audio LabsBugle3$199
74​
40​
114​
0​
N/A3/18/23Review Link
Parks AudioPuffin$400
73​
40​
113​
0​
Yes1/25/21Review Link
Parasound200 Pre$895
69​
43​
112​
0​
N/A09/11/21Review Link
Musical SurroundingsNova 3$1,500
69​
43​
112​
0​
N/A12/29/20Review Link
RanePS1$50
75​
36​
111​
0​
No5/16/19Review Link
Pro-Ject Audio SystemsOptical Box E Phono$200
76​
34​
110​
0​
No12/13/20Review Link
Pro-Ject Audio SystemsTube Box S2$400
69​
40​
109​
0​
No4/26/20Review Link
Graham SleeGram Amp 2 Comm'tr$299
69​
39​
108​
0​
No04/11/22Review Link
Darlington LabsMM-5$199
64​
41​
105​
0​
No7/24/21Review Link
ART Pro AudioUSB Phono Plus$99.99
59​
45​
104​
0​
No08/03/23Review Link
Hagerman Audio LabsBugle2$150
61​
40​
101​
0​
No8/14/20Review Link
Realistic42-2101A$20
58​
38​
96​
0​
No1/22/21Review Link
NADPP 4$229
54​
42​
96​
0​
No04/06/21Review Link
Lounge AudioLCR Mk3$300
53​
40​
93​
0​
No04/07/19Review Link
Chord ElectronicsHuei$1,500
44​
49​
93​
0​
No11/07/20Review Link
RollsVP29$50
49​
41​
90​
0​
Pyle AudioPro PP444$13
48​
35​
83​
0​
No10/15/19Review Link
FurutechAlpha Des Labs GT40$525
40​
41​
81​
0​
No10/05/19Review Link
There were nine MM + MC head amps, and one other MC only - the Graham Slee Reflex C.
I changed the SINAD figure for several amps, either because the Review Index figure was for the ADC or DAC, or quoted MM instead of MC.
Its interesting reading, though. Congratulations Michael!
Here we go, arranged in order of MC noise+gain, then MM noise+gain:
Brand
ModelPrice
USD
Date
Review
Link
MMMMMMMCMCMC
73​
69​
142​
64​
43​
107​
54​
73​
127​
SOTAPyxi$300
80​
46​
126​
65​
59​
124​
84​
39​
123​
63​
60​
123​
SchiitSkoll$399
81​
41​
122​
64​
59​
123​
ParasoundZphono$200
76​
47​
123​
56​
59​
115​
78​
34​
112​
60​
52​
112​
65​
44​
109​
51​
61​
112​
VincentPHO-8$250
73​
40​
113​
51​
58​
109​
0​
59​
50​
109​
67​
40​
107​
48​
60​
108​
86​
39​
125​
0​
SchiitMani 2$149
81​
44​
125​
0​
82​
42​
124​
0​
79​
42​
121​
0​
80​
40​
120​
0​
RegaFono Mk3$400
78​
41​
119​
0​
78​
40​
118​
0​
SchiitMani$130
74​
43​
117​
0​
80​
36​
116​
0​
76​
40​
116​
0​
76​
39​
115​
0​
74​
40​
114​
0​
73​
40​
113​
0​
69​
43​
112​
0​
69​
43​
112​
0​
RanePS1$50
75​
36​
111​
0​
76​
34​
110​
0​
69​
40​
109​
0​
69​
39​
108​
0​
64​
41​
105​
0​
59​
45​
104​
0​
61​
40​
101​
0​
58​
38​
96​
0​
NADPP 4$229
54​
42​
96​
0​
53​
40​
93​
0​
44​
49​
93​
0​
RollsVP29$50
49​
41​
90​
0​
48​
35​
83​
0​
40​
41​
81​
0​
Great work.
Isn't the price of the MC pro now a little bit higher now ;) .
Would be great to see the Spartan 20 tested, I'm guessing it would be in 2nd place.
Great work.
I would hope so. I'm working on a new generation of stuff that can be built using automated methods, so perhaps the price situation could change to the advantage of the buyer.
Almost certainly only for the better. I'm not prepared to release anything that doesn't improve on the previous version. Designing this for automation is a little tricky, though, but not necessarily impossible.
@Michael Fidler I feel incredibly fortunate that I snagged one of your last MC Pros this summer when I did!
It's an excellent MC phono stage, it's connected to a Denon DP 3000NE and I regularly rotate between three different cartridges, a Hana SL, a Denon DL-103, and an AT33PTG/2. The mono switch is so nice for the my small collection of mono records, much more practical than investing in a mono cartridge.
The MC Pro replaced a Schiit Skoll that caused excessive speaker cone movement and an aging Creek Audio OBH 15mk2
I don't know how one could setup a blind A B with different cartridges to verify the MC versus MM differences without two completely identical systems, but I believe that I notice fuller or less distorted sound in the <200Hz range with my MC carts versus my remaining MM cart, the Nagaoka MP 150. Of course this is sighted and biased.
