You need do your own blind tests. No, it's not strange to mention the benefit of lower distorion if it's actually high. What's weird is marketing benefit of lower distortion in an area where it's already extremely low.
I have to myself. That's good enough for me.Feel free to set out to disprove if you'd like.
I'm not selling GaN or have no financial interest in it either today. Quite the contrary, I'm selling amps with Hypex and Purifi.GaN has its obvious advantages. But transparent is transparent. Whether Purifi, Hypex, or a properly implemented GaN amplifier. It just so happens one of these options costs considerably more. Maybe that's why you're pushing it?
I misspoke.I have to myself. That's good enough for me.
If you want to see a direct apples to apples comparison for GaN against traditional MOSFETs there's a good one:I have to myself. That's good enough for me.
icepoweraudio.com
Because the limited bandwidth of the test can't see the rise. Not because the rise is not happening. Do the same test and test bandwidth as the amps you are claiming you can see the rise on and you will see it with this (fictitious) amp also. Or perhaps it is so amazing that it doesn't do that. But without a test done with a 45kHz measurement bandwidth, we'll never know.But we don't see the same rise as we do with silicon MOSFET amps. And that's my point.
The graph I showed earlier of a GaN amp (prototype that doesn't exist on the market and may perhaps never be released) was shown with 22 KHz, which is typically the accepted standard. Sure, with higher bandwidth the distortion would be higher. But we don't see the same rise as we do with silicon MOSFET amps. And that's my point.
We can look at a measurement conducted for both a Orchard Starkrimson GaN and Purifi 1ET400A by Audioexpress.
The Starkrimson GaN:
And the Purifi 1ET400A:
Source: https://audioxpress.com/article/fre...d-audio-bosc-and-purifi-audio-eigentakt-eval1
Notice that with the Purifi the distortion rises much quicker at higher frequencies. This would also be much worse for the Purifi above 2 KHz with a higher bandwidth. I don't know whether Audioexpress measured with 20 KHz or 22 KHz but it wasn't 45 KHz.
A poor implemented GaN amp obviously doesn't prove anything. There's no doubt that a well implemented GaN has advantages. Less rise in distortion at higher frequencies, close to a perfect squarewave and more efficient. What it comes down to if what's audible and that requires proper testing. People need to conduct that for themselves.
As mentioned before, I see no benefit with newer silicon MOSFET class D amps with simply lower SINAD numbers.
For integrators or those who want to experiment with front-end design, the Purifi is the clear choice. For someone who just wants an amplifier to run the stereo, one of the many integrated versions of the Purifi or (if going for separates) the Orchard BOSC will do pretty much equally well — and by “well” here, I mean “superbly.” Special system requirements (e.g., common grounding between channels) or just a non-sonic esthetic choice (e.g., look, feel, reputation) might sway a prospective purchaser in one direction or another, but soundwise, either is essentially perfect.
Any measurement differences seen here fall orders of magnitude below human hearing thresholds.
I'm well aware of that article. Did you notice that they don't look at THD+N vs frequency? And which is what I have primarily pointed out.If you want to see a direct apples to apples comparison for GaN against traditional MOSFETs there's a good one:
Is GaN worth it? - ICEpower
icepoweraudio.com
The benefits as it seems is efficiency and the potential of high power.Nothing else audio-wise.
when using GaN but most importantly the idle consumption is 20% lower and when this is combined with the efficiency of a switch mode power supply it will be more like 40%.
You can surely tell by the 6.67kHz measurement though.I measures straight as the 1kHz one even though I suspect 20kHz BW only as usual.Did you notice that they don't look at THD+N vs frequency?
This is again clearly bandwidth limited. I don’t see anything special here.Another benefit is close to perfect squarewave response (some mild over and under shooting in the corners with the GaN amp below). I'll take that over lower SINAD when it's already super low as well.
This argument seems slippery and weak to me.My conclusion based on tests today is that neither Hypex or Purifi are transparent under all conditions. There's potential audible distortion that can lead to some harshness with the right material with high enough volume (doesn't need to be super high though)…For me this comes down to actual listening tests and not simply consider it from a theoretical standpoint.
How do you know for sure it's between 90-100 SINAD around 5 KHz? Crest factor can still be high here, which will draw considerable power at some distance.This is again clearly bandwidth limited. I don’t see anything special here.
So you’re claiming to hear differences in distortion beyond 5 kHz between 90 and 100 SINAD with (some) music? I very much doubt that.
Well, given that the average spl at those frequencies will be some 30 dB down from the bass notes, it will be about a factor 1000 less power at those frequencies as well. There is no considerable power at those frequencies…How do you know for sure it's between 90-100 SINAD around 5 KHz? Crest factor can still be high here, which will draw considerable power at some distance.
To tell the truth here 5kHz is still low to have such a roll-off with new stuff.Well, given that the average spl at those frequencies will be some 30 dB down from the bass notes, it will be about a factor 1000 less power at those frequencies as well. There is no considerable power at those frequencies…
This waveform is solely a function of the small signal transfer function of the amp and this is determined by the control loop design and has virtually nothing to do with the type of transistors used in the power stage.Another benefit is close to perfect squarewave response (some mild over and under shooting in the corners with the GaN amp below). I'll take that over lower SINAD when it's already super low as well.
Based on the measurements I've seen and considering crest factor for this area as well as speaker sensitivity and distance, SINAD can be as low as 70 dB at areas between 5 KHz and 8 KHz.Well, given that the average spl at those frequencies will be some 30 dB down from the bass notes, it will be about a factor 1000 less power at those frequencies as well. There is no considerable power at those frequencies…
Really?To tell the truth here 5kHz is still low to have such a roll-off with new stuff.
Works like Billie Eilish - Ocean Eyes for example have the same energy there as at the 800Hz ballpark and there's even way worst examples.
That's how it looks like with peaks:Really?
There are some blips past 8 kHz (good luck hearing 16kHz distortion residue about 100 dB lower than the loudest parts). Otherwise, there isn't very much going on past 4 kHz. Never mind the dropoff past 17 kHz, I grabbed this from the official YouTube video of the song, so bandwidth is a bit limited. Overall, though, I'm still right, it's about 30 dB down from the bass and 20 dB down from 100 Hz to 1 kHz. Even if there is a higher crest factor (let's say it's 5 dB more), it's still between 15 and 25 dB less power, so between ~30x and ~300x, give or take. That means that when your bass is pumping at 200W, the tweeter will do somewhere between 0.7 and 7W beyond 5 kHz.
And yes, there will be exceptions to this, as there always will be. That still doesn't mean you'll be able to hear the distortion.
I don't think it's that different, It seems like mostly a display thing. Showing 160 dB of dynamic range isn't exactly ideal. Here are the two roughly overlayed:That's how it looks like with peaks:
FWIW I did a test on me to get an idea of what level of didtortion I was likely to be able to hear or at what level it seems to me it would be masked.Do you think an IMD product at 7khz 70db down could be audible?
