In my opinion, any measurement of THD+N (or SINAD, if someone wishes) is pointless if the author does not declare the measurement bandwidth. Without BW declared, it is rather a promotion and marketing than a scientific valid parameter/plot.
)Agh - sorry. My post has been edited.please direct the questions and comments to the poster @Bjorn. its not my chart…
To be fair with the posted chart,even if the BW is restricted to 20kHz it does really good close to 6kHz where the danger zone is and H2 and H3 are well inside the BW.@Bjorn - And again - which amp are you talking about. If it is the P400 I've shown @amirm 's test from, then that is a hypex amp.
Can you link where you got the bandwidth limited chart from?
Your chart/measurement (if it is 20kHz bandwidth) simply fails to measure distortion properly on signals starting at around 7kHz. (2nd harmonic and higher ignored), and all distortion is ignored above 10kHz (even first harmonic is outside the measurement)
NOTE - the measuremnet bandwidth doesn't specify what signals (the lines on the chart) are applied. It refers to the maximum frequency of harmonics that can be seen (measured). So if the test signal you are measuring the distortion of is 10.1kHz, then the first harmonic is 20.2kHz - and a measurement limited to 20kHz bandwidth wont see it. This is why the distortion lines on your chart start to reduce above 5kHz (where in reality the actual distortion will be increasing, as you can see happening up to 5kHz.)
This is also why Amir uses 45kHz measurement bandwidth as stated at the top of the chart I provided.
(EDITED to remove my dumbass confusion with who I was replying to)
so THD+N rising up to over 0.001% before clipping is considered good nowadays? You think this is better than gen 2 ET?This rise tends to be history as we go forward.
See new purifi for example.
Or better still the new icepower conductor which has the same (and better) THD+N at the worst audible case 6.67kHz than 1kHz all the way to its full power:
(link but I would love to see it verified by third parties)
(also here at an actual module)
So,we better not generalize and wait.
Better than the purifi?Of course not.But it's a lot cheaper too if one considers that as a criterion (242 EUR for the stereo "125" W module or 143 EUR for carton 36 pcs with PSU onboard)so THD+N rising up to over 0.001% before clipping is considered good nowadays? You think this is better than gen 2 ET?
We rather use the term “first harmonic” for the signal base frekvency. So the 20kHz sine signal has second harmonic distortion component, H2, at 20kHz.So if the test signal you are measuring the distortion of is 10.1kHz, then the first harmonic is 20.2kHz - and
And you did those double-blind?For me this comes down to actual listening tests and not simply consider it from a theoretical standpoint.
Please show evidence of GAN devices as a category showing better measurements across the board using the same test conditions.This is solved with GaN due to higher switching. Another benefit is square waves and slightly higher effiency. Chasing lower SINAD isn't a step forward IMO.
My conclusion based on tests today is that neither Hypex or Purifi are transparent under all conditions.
www.audiosciencereview.com
Lol indeed. In any scenario short of technobunker/concert/full blast orchestra levels, that isn't just inaudible. It's physically nonexistent. If max is 100dB peaks and distortion is -100, exactly zero of it is in the air.Good luck hearing -100dB of distortion when your amp is pumping out 70W.
Nonsense. You don't understand audibility of artefacts.There's potential audible distortion that can lead to some harshness with the right material with high enough volume (doesn't need to be super high though).
Any measurement differences seen here fall orders of magnitude below human hearing thresholds.
Right and since the author didn't hear any difference between the amps, that is of course an objective truth for all humans at all ages with all music materials with all speakers at all level as well.From the review article itself:
Ok... so why do you seem to be pointedly ignoring the question of whether these audible differences you claim exist have been proven in a double blinded listening test?Right and since the author didn't hear any difference between the amps, that is of course an objective truth for all humans at all ages with all music materials with all speakers at all level as well.![]()
Feel free to set out to disprove if you'd like.Right and since the author didn't hear any difference between the amps, that is of course an objective truth for all humans at all ages with all music materials with all speakers at all level as well.![]()
