Or, much more likely - good old perceptive bias.and I suspect it is because of their much higher switch frequency at 1.1MHz.
Can you explain why I should have a bias for Orchard vs other class D modulesOr, much more likely - good old perceptive bias.
You might know best. The subconscious plays many tricks. We are all subject to the bias.Can you explain why I should have a bias for Orchard vs other class D modules
Does it matter why? Bias can be ,and most often is, unconscious. This is why you cannot shut it off and why controls are needed when making any such comparisons.Can you explain why I should have a bias for Orchard vs other class D modules
Perceptive biases are how our human senses work— all of them. Don’t think of it as a prejudice— it is more analogous to a system. Bias— like biasing a transistor. They are often the reason optical and aural illusions work, for example.Can you explain why I should have a bias for Orchard vs other class D modules
I worked part of my live in the Pharma industry and I know about double blind testing but I can not assemble an amp module with my eyes closed. Also if I bought 2 different modules my bias for one or the other would be at least quite small. But as I said I still would like to see measurements especially is there a significant difference at higher frequenciesPerceptive biases are how our human senses work— all of them. Don’t think of it as a prejudice— it is more analogous to a system. Bias— like biasing a transistor. They are often the reason optical and aural illusions work, for example.
What we hear is impacted by what we know, what we believe, how we feel, our life experiences, what we see, etc. No one is immune to this if they are human— it is how we are built. In fact, we would be unable to function if our senses were not filtered by our unconscious brain. Everyone is subject to this; it happens at the unconscious level, and it is not possible to avoid it— even when we are aware it is happening.
Biases are why controlled testing is always needed when human perceptions are involved— for example, double-blind trials of medicines.
Also— why whenever trying to test human perceptions of sound, well-controlled blind listening is needed.
No one is asking you to. But generally in this place - subjective uncontrolled descriptions of sound differences which are vanishingly unlikely to actually exist in the sound-waves reaching your ears - are going to be questioned. Uncontrolled listening is insufficiently reliable to give those descriptions any validity.but I can not assemble an amp module with my eyes closed.
Maybe this is sarcasm? It's going to be transparent like all other ncorehypex.A hint of smooth warmth with extreme detail and dynamics. Musical but touching the analytical side.
Are pharmaceuticals made by blindfolded people? What a silly thing to say..I worked part of my live in the Pharma industry and I know about double blind testing but I can not assemble an amp module with my eyes closed.
It doesn’t matter what you think. You have no control over your biases. Maybe you linked the newer enclosure better? Maybe it’s the price differences between the modules? It can be so many things. But most of all, any volume difference more than about 0.1 dB will throw off any reliable comparison because the perceived frequency response difference will actually make them sound different.Also if I bought 2 different modules my bias for one or the other would be at least quite small.
It's not off the shelf, TEAC has them specially tuned and made for them...Maybe this is sarcasm? It's going to be transparent like all other ncorehypex.
But controlled tests are… I’m sure you did not do such a thing.but measurements aren't everything
If you want to believe measurements are everything thats up to you.But controlled tests are… I’m sure you did not do such a thing.
So why are you even here if you deny the core science this forum tries to promote?If you want to believe measurements are everything thats up to you.
I'm a subjective > objective listener
TEAC gear is exceptional
This is audio science review. The rest of the hi-fi internet matches your approach; this place very definitely doesn't.I'm a subjective > objective listener
They bypassed the NE5532 based input/gain stage as instructed page 7 of the datasheet. 3 resistors removed and 2 jumpers added. Calling this "special tune" is an exageration from the marketing department.special tuned Ncore modules
bUt iT's LeSs sTeRiLe nOw!!!3!They bypassed the NE5532 based input/gain stage as instructed page 7 of the datasheet. 3 resistors removed and 2 jumpers added. Calling this "special tune" is an exageration from the marketing department.
Do you have any objective evidence that any differences that might result (noise, distortion, frequency response) are at a level that is actually audible? Because at the moment you are just sounding like every other audiophile, deluded by a fancy marketing story.It's not off the shelf, TEAC has them specially tuned and made for them...
Just a touch less sterile than off the shelf ncore modules....ive heard a few other Ncores and purifi, I like the TEAC implementation best. It's a little more full....sort of like classic denon sound with nice upper midbass.
The implementation makes a HUGE difference along with power supply. The modules has less to do with it....but Ncore is a solid performer. Lots of builders have gone back to it over better measurement newer modules....but measurements aren't everything.
