120 at the receptacle. 2400 watts to trip the breaker. A 1200 watt microwave with a 1200 watt drawing toaster will do it.Ever heard of 1/5th actual music power vs rms power?
20A at what voltage?
Fans are made by Arctic, F12 or P12 PWM.Can you share make and model of there fans? Are they 12 or 24 volt? Crown uses 24 volt which creates issues when trying to use 12 volt silent computer fans.
What about vibration? Seems like the only effect it could have on reliability would be a shorter life span.I also remember somebody asking if putting plate amplifiers into a subwoofer box is detrimental to reliability.
Yes, if they are allowed to overheat.
Shorter life span is lack of reliability, allowing components to run too hot.What about vibration? Seems like the only effect it could have on reliability would be a shorter life span.
A seperated vented enclosure, cooling inside of amp by convection and a fan if necessary.Plate amplifiers inside a subwoofer (or any other enclosure) are more attacked by missing a own enclosure than overheat (if I interpret the reviews I've seen correctly).
Batten the hatches.What about vibration?
Monitor internal temp in extreme use.A separate enclosure does not only prevent an external vibration but can serve for severe ventilation. Hypex, for example, have their own examples, how to adjust their plate amps (they do have openings on top and on the feet).
Can it be that:
1) being less expensive, sales of MPs are or have been greater than those of any specific “higher end model” ?
2) MPs have been around for a longer time and therefore it is reasonable to have more anecdotal reports of problems?
or, I presume less likely
3) people who can afford “higher end models” are less likely to report problems, particularly to social media?
4) people who purchase the less expensive equipment are less likely to worry about how carefully they treat them?
I could go on, but the point is that there are many possible data collection biases that can come into play when the data are anecdotal.
Why was this guy deleted, if not a silly question?I view reliability somewhat differently than perhaps a few here. In my mind, reliability is not incidental or accidental. It occurs when that quality is seen as a primary and desirable characteristic. In other words, you don't design for efficiency, or effectiveness, and have reliability just happen. You have to design for reliability at the same time as efficiency or effectiveness, and then see how efficient you can make the device, or how effective it can become without reduction of that necessary reliability.
I don't see that happening today. Not in audio, and not in anything else. Jim Taylor
Maybe deleted themself. Not necessarily a mod move.Why was this guy deleted, if not a silly question?
He said some good stuff, hello? deleted member?Maybe deleted themself. Not necessarily a mod move.
