There are many ways to filter the air that is being pulled in (It's not like you need sub-micron filtering.Fan subject.
I always wonder if the benefits or using a fan and having the components a bit cooler is not countered by bringing more dust to the inside and risking an electrical failure in the long term.
I am talking about the case when a fan is not absolutely necessary, obviously.
Anyone with an informed opinion?
Note that opening the device to clean the dust from time to time also brings some additional risk.
Sometimes all you need is a dryer sheet cut to fit & taped into place.
A layer or 2 of gauze.
If you want to get serious about it: a couple of layers of gauze with 2 more layers that have been sprayed lightly with the (normally used on cars) K&N air filter (a very tacky substance that catches most any minute solid that tries to pass through it at the low flow rates we are using here {compared to a car at wide open throttle).
Why the initial 2 layers of gauze not having this oil on them: they will absorb some of the tacky oil (which is not something that drips), but sort of migrates a bit over time.
So I would suggest another layer of gauze over the top.
Now you have a 5 layer gauze filter sandwich that will keep dust, pollen, etc from the inside of whatever you are pulling air though.
There are many ways to defeat the dust.
For me, I use are filters on my home ventilation system made by the company that supplied the ones for the NASA Space Shuttle program.
Officially they are MERV 8 in airflow but they filter as if they are MERV 13 while flowing like MERV 8 filters (The Name of the company is :Colorfil.
I also use 2 Honeywell HPA 3200's with HEPA, SMOKE & VOC filtration in them. Each one covers up to 520 square feet of a 8 foot ceiling building.
(My use case, at the moment is 1100 SQ. Feet [but that includes a small screened in patio], so we are filtering under 1000 SQ. feet).
These units are available at or through Home Depot, though you will likely have to order the additional VOC part.
Without that they are still a HEPA filtration level of filtering.
It's not hard or expensive to keep ones place so that you don't have to dust & vacuum every week.
Another thing that we do is have slippers inside of all doorways to the outside, so that, the moment that you come in, you change from your outdoor shoes.
Yep, you guessed it, my wife is Asian. But it's a good policy IMHO.
EJ3
