Back in Posts 254 and 255 I described yet another Class D module failure that I had experienced. This one was an ICEpower 50ASX2 that recently just wouldn't turn on. I ended up ordering another 50ASX2 module from China and proceeded with the removal and replacement operation as that was the easiest solution and just under $100 for the shipped module. This was the 3rd module failure out of 6, and with this replacement now 7 Class D Modules I have purchased.
I removed the approx. 5 year old module that had very low hours on it, and as I started to install the new module in its place I noticed it had only one speaker output connector. Upon closer examination I realized they had sent me a BTL (mono) module to replace my SE (stereo) module. All that really meant was that I needed to rob one of the speaker connectors from my dead SE module and install it in the new module, and also remove the BTL soldered-in jumper and install an SE soldered in jumper. Not a big deal but the additional desoldering/soldering work added some 30 minutes to the project. Their solder has a really high melting point! I guess all is well that ends well, as the amplifier now is playing fine with the new module in it.
Having the dead module completely out of the casework led me to perform a closer visual inspection of the failed module looking for signs of the failure. Yes, there were two components that had let out some magic smoke that was apparent on some white adhesive glue and and adjacent white plastic connector. It's not worth doing on board repairs from a time and energy standpoint with a module this inexpensive, but I can share close-up pictures of the parts that I could visibly see went Chernobyl:
