Then there is (real) class A, G and H which they still haven't doneI think it's just because they can... they've done D, AB, so now B. They seem to like covering all bases in the market.
JSmith
What?!
Pr1 adjusts the output stage bias current so that Amp can be class B or class A/B. And TR13 should be on the output stage heat sink to keep the bias constant with temperature of output devices."Class B", there have bias voltage and changes with the temperature of the output stage BJT,the bias voltage is small,so maybe we can call it “Class B”
As discussed by others, TR13 and the circuitry around it allow it to be biased in class AB, and unless TR13 is biased completely off (unlikely if you want a functional circuit) then there is the potential for trickle bias current in the output devices though it can still operate in class B as long as the Vbe multiplier (T13) is set appropriately. TR13 will also affect the temperature coefficient, of course, so it unless it exactly matches the output devices in bias ratio and temperature there will be drift with temperature.its realy class B and composite circuit
I am not sure the purpose of your posts? There are a number of design engineers here that are very knowledgeable regarding amplifier design (and many other things), including classes of operation, biasing, and feedback (as well as feedforward) compensation. Do you have additional insight about the Topping B100 design in question?Negative feedback will solved anything.Only one BJT will "on" anytime.
7/16Yeah, you are right. Anyway, I was curious. The test files, together with delta (difference) file are here:
xoverdist.zip
drive.google.com
"Optimalbias" is with 22mV across 0R22 Re resistor (100mA current), "zerobias" measures 0.0 mV across Re resistor, so there may be some negligible current as the lowest measurable voltage was 0.1mV (0.45mA current). Spectra at 1.5W comparison:
View attachment 392824 View attachment 392825
Though the deltawave delta file sounds ugly (but only after huge unrealistic amplification), the files are indistinguishable to me by listening.
Paul's @pkane excellent Deltawave software says:
View attachment 392826 View attachment 392827
The crossover distortion should have been much higher to be audible. Even in this 55 years topology a moderate feedback factor made the crossover distortion inaudible with music.
That’s what Amir said … yes it’s class BIs Topping B100 class B?
