Class AB amplifier for measuring on a PWT
Elysio
Hi community.
I have a special request.
I am searching for a class AB amp with very low K2 and K3.
I want to use it as a measuring amplifier on a PWT , plane wave tube.
Now I am using the Aiyima A70, which is a good amplifier. But it has one major drawback.
It is a class D amp and with that I can not use it for impedance tests or any other test where
It can accidentally happen touching ground and the equipment
will blow up, because the class D amp is floating. I.g. like a voltmeter with ground etc...
Is there a affordable class AB amplifier with very good noise and distortion values ?
A short information for the purpose. I am measuring compression driver on the plane wave tube.
I am developing those compression driver and to get a more accurate feedback of my developments
I have to measure K2 and K3 distortions. For that it is important to have a amplifier with ultra low
distortions.
They are using the LM 3668 chip. How can they reach such low distortion values if the chip itself dies not offer such low distortion values ? Strange, isn't it ?
The Modulus series amps are composite designs. See thread at DIY Audio for more info.
There are two ways to build a measuring amp: Buy ready made and very expensive or DIYS and save on money, but pay with a little time.
If you don't know how to DIYS, you may get help in some so called DIYS HIFI forums.
The basic -86 Neurochrome amp will fit your needs.
The Outlaw 2220 has low distortion. I don't know if it suits your needs overall but the distortion is slightly better than the Aiyima A70.
edit: now I see you did also say low noise in your OP. The outlaw might night have low enough noise for you.
