This wideband noise is probably before the switching stage and hence does not depend on A or D etc. Topping LA90 is SOTA hence <2uV
Well yea ncx500 is lower SNR by quite a bit as predictable by their respective SINAD performance (noting that ncx500 has slightly higher gain than LA90 here, in fact it's around 2dB higher, which when you add to the 7dB difference in SINAD results in 9dB difference in noise performance, surprise surprise *not really*), but lets look at something with similar SINAD and is not a class D:
ncx500 actually has better noise than AHB2.
All numbers are at 5W output
Just to round things up, below are two amplifiers with similar SINAD performance:
So no, noise level is not a function of class AB or D. But it has good correlation with SINAD. Good amps have less noise, cheaper amps have more noise, that's all. Of course just like opamps you can have designs more tuned towards low noise versus some other priority.
One last thing to note, the datasheet numbers are only best-case scenarios. I'm sure some of us have encountered this, when a speaker's power adapter spoilt and we replaced it with another, it has a buzz that is not there with the original power adapter. Power supply (and the related common-mode a.k.a. ground noise) limit the final product. Which is why 3rd party measurements of end-user products are more useful than first-party datasheet of the individual IC. Although such measurements still do not cover common-mode noise simply because we have not measurement standard or criteria for it.
