Not really qualified, as audio amplifier design is not my day job. But
@restorer-john provided excellent examples in his post. Here are my thoughts, though hopefully some of our more learned audio designers will chime in to correct my mistakes:
Thank you for replying.
The class A designs I have seen have much higher (often an order of magnitude or more) noise and distortion than comparable or higher-powered class AB designs. How much of this is design choice (e.g. lower feedback) and how much is a limitation of the operation (higher bias means more noise) I could not say.
There is no technical reason for this assertion, perhaps you have been unlucky or tested crapy amps. In case of "Single Ended" amps you may have a point (actually a lot of points) but a like for like, Differential class A amp vs Differential class AB of similar manufacture, class A wins, it will have lower noise and lower distortion, I claim it is inherently superior, but bad design and or manufacture is another story.
Class A or class AB reffers to the output stage
only, so let's keep that in mind.
Class AB offers much more power and the potential for even larger dynamic headroom for the same size, weight and power (SWaP) as a class A design which has much lower power output, greater heat, and typically (IME) higher noise and distortion. The best a class A output stage can do is about 50% efficiency (for push-pull, ~27% for single-ended) so at least half the power is wasted heat. The heat shortens the lifetime of the components inside and increases thermal (Johnson) noise. The high bias current increase current (shot) noise. Additional devices are needed to support the constant current in class A designs, which means they add their own noise (from internal resistances and such) and reduce bandwidth (from all the extra parasitics, though of course you can beef up the driver stages to compensate). That also reduces slew rate that can be achieved and potentially increases TIM (transient intermodulation distortion). Class AB amplifiers typically have greater loop gain and higher feedback so their distortion is lower, though of course part of that is design choice -- lower feedback seems to be a marketing point these days. The high constant bias of the output stages constrains the gain and feedback you can provide, though this is a more practical than theoretical issue. Given the high peak-to-average power ratio typical of music and movies the extra power can be very helpful compared to clipping a lower-powered class A amplifier.
No argument that class AB is more efficient (more power less heat, less electricity). Class A is also heavier on the PSU and components life, agreed But the issue in question is
fiedility only.
Constant current in class A designs?? perhaps you can clarify.
A diffrential class A power section has noise rejection same or better than class AB. If designed correctly, TIM of a class A amp should match or better class AB. Class AB requires HIGHER global feedback than class A to control any residue crossover distortions, so gain must be worse (but who cares) output stages are mostly unity gain. One should not compare a 10W class A amp to 50W class AB, let's keep it like-for-like. Not everybody requires tons of power. My office amp is rated at 6W, and it is plenty for my use.
One thing you really have to watch is what happens when the amp clips. Class A clipping means the output runs out of bias current, perhaps dumping to the load, and overload recovery can be "interesting" as the feedback loop (what there is) opens up and it can take some time to "pull" the devices back into linear operation due to all the charge storage in the output stage devices. Class AB can have similar issues, but as only half the waveform is immediately impacted, tends to recover better. Or there may be other reasons; not something I have thought about much, I have just observed a trend favoring AB for better overload recovery. But this is my experience and I have not tried to do a detailed theoretical analysis, nor is it something I have spent a lot of time researching on paper or in the lab.
I don't believe that is the case, perhaps someone can shine a better light on this. Properly designed class A amp should recover no worse than class AB.
So aside from the price, heat, and so forth, performance-wise the trades for class A are higher noise, greater heat leading to shorter lifetime and worse reliability, higher distortion, and lower power. Where class A is typically marketed is at low power levels because they have no crossover distortion, although push-pull designs still exhibit some distortion at low levels because of gm-modulation of the devices as load current switches from one set ("side") of devices to another. However, a class AB design runs in class A at low levels so also has no low-level crossover distortion, so this tends to be a wash.
HTH - Don
Again, class A being less efficient is agreed, but I dispute higher noise and distortion, unless you are talking single ended output stage.
We should keep in mind that class AB is basically class A for small signal, and class B for higher power. It is a technique/trick to get more power out of a device, it was not conjured up to cure any other shortcomings.
If one needs higher powers, class A is not convinient to maintain, but that was not the question.
A member with a horn loudspeaker needs only a few watts, of super clean signal.
