Too bad, I am highly suspicious of that curve being an accurate impedance magnitude plot.
Why only discuss A & A/B?
I'm sure these have been measured and subjectively reviewed as sounding fine with Hypex etc - they will drive anything, including a concrete wheel-barrow.
Home
Nord Acoustics supply Hypex Amplifier NCore NC500, NCx500, NC1200, Purifi Amplifier 1ET400A, 1ET7040SA. Hand built using discrete op amps and voltage regulators, Worldwide delivery.www.nordacoustics.co.uk
I remember when Stereophile was accidentally inverting the impedance magnitude curves. At some point, they realized it and quietly fixed it. I wonder if that's what happened here? It would make more sense upside down.These speakers have very impedance below 3 ohms below 60Hz and above 2kHz.
Some ASR amplifier reviews include power by frequency and some amps including Hypex Amps have reduced power into low and high frequencies, and other seem good.
Hypex:
Purify amps may be up to the task as well as beefy A/B amps.
Putify:
NAD M33 Streaming Amplifier Review
This is a review and detailed measurements of the NAD M33 Streaming Player with Purifi Eigentakt Amplification. It is kindly sent for testing from a member and has a retail cost of US $4,999. The NAD is part of their "Masters" series and has one of the best industrial designs of any audio...www.audiosciencereview.com
I'd like to see all amplifier reviews include the power by frequencies measurements.
2 Ohms testing may be worthwhile for beefy amps.
- Rich
Not mutually exclusive. Even upside down, there’s a lot of peak and dip, but it looks more normal. Ditto if it’s a phase curve, the integral will give a rugged magnitude.Maybe, but my brother had pair of small Kappa and they were very hard to drive.
- Rich
1ET400A - PURIFI
Single-channel, analog-input Class D amplifier module Negligible THD and IMD Extraordinary low noise Load-invariant response Exceptionally clean clipping Low losses & high efficiency Easy to integrate Designed in Denmark KEY SPECIFICATIONSpurifi-audio.com
JSmith
That goes against the prime directive to not damage gear when testing it. A 2 Ohm load is punishing for stuff and then poof the smoke is let out.2 Ohms testing may be worthwhile for beefy amps.
One of the tests I've applied to amplifiers I've bought for my own use is to put a screwdriver across the 'speaker terminals at full power. If it doesn't survive, it goes back. Obviously, I wouldn't do that to an amp that wasn't advertised as short-circuit protected. but then I wouldn't buy one that wasn't, so I do test it.That goes against the prime directive to not damage gear when testing it. A 2 Ohm load is punishing for stuff and then poof the smoke is let out.
Where do we draw the line between expected to take 2 Ohms and the other stuff not req'd? Plus the gear is sometimes used and we don't know the condition of the circuitry. Maybe there is a fault just waiting to blow up. Then there must be a test time limit and 1KHz or 20-20KHz into 2 Ohms? Things will become hot.Good amplifier MUST handle 2 Ohm load. And testing into 8 Ohm is pointless.
It is important that anyone having properly engineered speakers must pay significant extra expense for the 0.1% of badly designed speakers out there that they wisely avoided. Because reasons.Where do we draw the line between expected to take 2 Ohms and the other stuff not req'd? Plus the gear is sometimes used and we don't know the condition of the circuitry. Maybe there is a fault just waiting to blow up. Then there must be a test time limit and 1KHz or 20-20KHz into 2 Ohms? Things will become hot.
EDIT:
Who will make this standard test?
The Kappa 9 is a very fun speaker to have about in the stable. I'd like to own one even with the low Z. They pound/thump pretty good when cranked up and the top end is decent too.It is important that anyone having properly engineered speakers must pay significant extra expense for the 0.1% of badly designed speakers out there that they wisely avoided. Because reasons.
Interesting comment on new Krell. I wasn't aware they didn't specify 2Ω output post-Dan until I had a look at the specs re your question. I also read Stereophile review of the Epsilon, I have a better idea now. Great to read about nice older gear.I have tried the 375 and they were nice but did not had enough power. Have not been able to test the 575 due to lack of distributors in Sweden. The 300 duo like the Evolution serie does not deliver current enough for the 9:s. Ok for the 8:s though. Epsilons design demands a minimum of two poweramps so maybe two Duos will work but it would be a step down from today. (I think…)
I was hoping for some lightweighted class D power amps. Maybe if I bi amp? Two, four or more of them?
Thanks all for taking time answering. And btw, as You can see above the Kappa 9 are really beautiful and sound fantastic. I am lucky enough to have my little Infinity collection in Santos wood.
If I find an alternative I let You know.
Cheers from Sweden
Due to lack of distribution I have not been able to test the Evolution monoblocks. If i can get a chance to test them I will. The only Evolutions I tested are the integrated ones which did not have a chance driving the 9:s. I am only searching for poweramps because I have three Krell preamps and are very, very pleased with them.Interesting comment on new Krell. I wasn't aware they didn't specify 2Ω output post-Dan until I had a look at the specs re your question. I also read Stereophile review of the Epsilon, I have a better idea now. Great to read about nice older gear.
Did I read correctly that Evolution series didn't work for you? I'd have guessed any Evolution monobloc (400/600/900 watt models) would do ample current (Krell specified doubling output down to 2Ω and Stereophile verified) and they have monster power supplies. My speakers are less demanding, but I keep an eye out for used 302e which looks like the sweet spot (for me, probably not you). I didn't suggest them because they are just as heavy as your older models (no exposed heatsinks though).
I'll agree with @Doodski and others that more recent Hypex or Purifi may be worth a look: here's the new one (vendor is from my country, there are doubtless EU implementations of Purifi 1ET7040SA coming nearer you if not already). Note spec has it near enough to doubling all the way down (250/500/950 at 8/4/2Ω) which is new for class D (I think, certainly for Purifi).
