Glad we could agree an the PS audio class D.The Stellar M1200? -
The BHK Mono 300:
If we are talking about a company's "best products" - well, PS Audio prefer tube input buffers. A MOSFET buffer is used on their cheaper amps.
For reference:
Review and Measurements of PS Audio S300 PWR Amp | Audio Science Review (ASR) Forum
This one with the MOSFET input stage is a recommended product here! The other power amps show "good enough" performance when measured elsewhere, no matter the topology. (The less said about PS Audio preamps and DACs, the better).
The class D modules they use may change frequency response with low impedance speakers, so it would not be a surprise if their MOSFET power stages are superior. Neither range is necessarily suitable for very low impedance loads, if you skip the marketing blurb and go straight to the specs, but I don't have any real problem with that.
So, if we limit ourselves to PS Audio I'd expect your assertion that they would claim their non-class D amp to be superior, to hold. It doesn't for Marantz though, and "I haven't owned one" doesn't cut it as a way out;
On Marantz, I never mentioned them, you did, I meant I don't know anything about their products; do they rate their class D above their other POWER amps? Good to know, although marketing could be involved.
Obviously you are in the measurement objectiviste camp. So, are you saying that a good Class D amplifier will out perform any class AB amp on any load (my speakers) no need to listen or compare. There seems to be a consensus of reviewers and end users, (me) that Class D amps sound detailed, transparent but "thin," anémique in the lower midrange, and lacking weight. Are we all half death or inhabited with exorcism?
