clarity C80 seem usefull for find good speakers. see measures . my big expensive speakers all have clarity Problems in Bass/Low mid. I hear this too
bennybbbx
germany
I notice by compare of speakers that big speakers have lots problems in clarity when compare in same room and mic position. I also hear that the small speakers both EQ so FR is very simular have more clarity when hear. My most expensive speaker the focal alpha 65 have the worst clarity in some parts and the Kali LP6. the cheapest the JBl 104 have the best clarity on bass and low mid.
Can the Klippel @amirm have show C80 vlaues ?. C80 is clarity time measure 80 ms . if klippel can show can the resolution better as 1/3 or is it 1/3 ? maybe the clippel allow also a custom time ?
So i think to find a good speaker clarity value is very important to have. the Waterfall Amir show is only 3 ms so bass or low mid problems of speakers can not see. I have add foam on some parts of my room and the diffrences get larger between speaker on hearing position. with foam i use speakers distance 1 meter now without i go not over 0,6 meter. is with the klippel in C80 or D50 also alot diffrence see between speakers or example between the focal alpha 65 evo and the JBL 104 ?. I measure in 66 db and 76 db level to be sure that problem is not because the bass on JBL 104 is lower. but between 66 and 76 db is not much diffrence in clarity. In REW it is possible to use a custom clarity time upto 99 ms. is ther other time as C50 C80 in Klippel possible too ? . with C50 there can only see less diffrence in bass and low mid. the higher the clarity time is set the more diffrence can see. My speakers have diffrence directivity, but as can see in measure directivity is not diffrent much for clarity or need better Clarity resolution as 1/3 for it, because over 900 hz there is very few diffrence in clarity
more infos and the measure data and photo how i measure you can find here. https://www.avnirvana.com/threads/i...her-resolution-as-the-t60m.16397/#post-122162 speakername and m mean 1 meter distance in middle of room. L mean speaker position on desktop 1 meter distance.
I think to find good speakers clarity is best and it is easy comparable with overlay.
If clarity work in near field systems to detect diffrence correct between speakers i did not know, when bass port and woofer is mixed.
