When I first read the concept:
When I saw the results:
-Ed
-Ed
It depends on the pedigree of the monitors too... Considering what can be found on the market, probably not worth spending more on an interface...This could be the solution to the minimalists who use studio monitors as desktop speakers and don't want the hassle of extra cables of an external audio interface or DAC. It really missed the mark though...
*sniffs*
I am guessing the pic is another AI fail.
Yeah go straight into your mighty B200 monoblocs (no mere single-ended inputs whatsoever) from your laptop.Trying to work out a use case. Perhaps someone bought or received an XLR only integrated amp and speakers wanting to connect to their phone or computer, perhaps?
Most of these cables and dongles use these chips or similar.If someone combined this concept with one of the Cirrus Logic CS43131 chips we'd be rockin n rollin.
One question:Gosh, this is not what I wanted to see. Instead of nominal 4 volt output, we only have 0.75 volt.
Some of these use this cirrus chip that won't allow 4 volts, but much more than 0.7, so probably the limit comes from the supplied voltage, or am inferior performance chip...One question:
Can you get 4 volts from an adapter powered directly by a smartphone? I imagine it has power limitations related to the smartphone's power capabilities, right?
This "SoundWire" is the only one i know that is protected against 48V phantom and works well.I see this style of device regularly used on live event work, usually for quick connections where ultimate sound quality probably isn’t the priority.
A key requirement of this device for me would be what happens when connected to a mixing desk and +48v phantom power is active. It is easily turned on by mistake or with some cheaper mixers it is a global switch for all XLR inputs. I’m not sure if this unit could tolerate phantom power or what would happen with the connection to the computer.
I have seen many non functional 3.5mm headphone sockets on laptops as a result of direct connection to 48v.
sonnect.com
USB-C DAC to dual ISO-XLR™
The SoundWire is the go-to USB-C DAC to dual ISO-XLR™ cable interface, reliably streaming 192 kHz, 32-bit audio from your playback directly to the mixing console, bypassing DI boxes and protecting against 48V.
Let's hope somebody comes out with a better performing version. Something for $50 or less would really be good. Thank's for this, Amir.
Using an on-board switching power supply you can get any voltage you want. We already have dongles with 4 volt output.Can you get 4 volts from an adapter powered directly by a smartphone?
Expensive, but a great product, use it often.This "SoundWire" is the only one i know that is protected against 48V phantom and works well.
SoundWire
The SoundWire is the go-to USB-C DAC to dual ISO-XLR™ cable interface, reliably streaming 192 kHz, 32-bit audio from your playback directly to the mixing console, bypassing DI boxes and protecting against 48V.sonnect.com
