I do hate it when I hear a meteor shower on Mars. Really takes me out of the music.Yes or something like it. It is core to Rob Watts' marketing talk on these products. Just watch any of his videos.
I showed the levels and they are very close. The key is that bypass is not bit exact and still attenuated same as when filtering is on.Im sure I read somewhere that switching from bypass to M-scaler "on" introduced a level change in the signal. If so it DOES make a difference to the sound (think M scaler was a db or so quieter).
I expected this forum to help saving time when choosing gear, not the other way around Besides, I don't rate my own assessment capabilities on this field very high so I prefer an objective measurement and read informed people's opinions.Every person can answer it for themselves with a blind test.
I'm far-far away from any camp but I think that is something odd there,is very strange that Topping was not able to reject the jitter.Im sure I read somewhere that switching from bypass to M-scaler "on" introduced a level change in the signal. If so it DOES make a difference to the sound (think M scaler was a db or so quieter).
Either way, it doesnt nothing useful yet the Chord squad will say something was flawed in the testing here I am sure.
The difference is there. You can also see it in this review.
But the real question is whether it provides an audible improvement or not. And that's not something we can answer definitely. Every person can answer it for themselves with a blind test.
Jitter is not a problem. M scale is modifying the input signal by scaling it and possibly with different voltage swings. One or both of these is causing a problem. I could do more testing to figure it out but I don't think it is important.I'm far-far away from any camp but I think that is something odd there,is very strange that Topping was not able to reject the jitter.
My point is that regardless thingies like this,any decent dac must be immune to any problem cames before it.Jitter is not a problem. M scale is modifying the input signal by scaling it and possibly with different voltage swings. One or both of these is causing a problem. I could do more testing to figure it out but I don't think it is important.
I'm glad someone found a use for all those old floppy drive cables.Gross yuck blah!
This product: a way to make insane profits from a device that does nothing.I don't understand this product, its target audience and its inner workings, so I refrain from voting. Nice blinky box, though.
To argue that is the same as entering a hornet's nest. I am scare of wasps, hence I will not argue
Waiting for the time when more companies, at least the engineering led ones, measure and publish performance metrics openly. Then we can move on
How can a dac can possibly know what the file that is fed to it was like? If you feed it something with bits in error, it will convert those erroneous bits.My point is that regardless thingies like this,any decent dac must be immune to any problem cames before it.
I don't care if is a magic sauce like that,a noisy pc or a raspberry.
That test works both ways.
Thanks Amir!
To it's specs thought.How can a dac can possibly know what the file that is fed to it was like? If you feed it something with bits in error, it will convert those erroneous bits.
CHORD is an engineering company, what they do often is pretty top-end engineering but their business model is marketing to audiophools. I found that disingenuous but here I am from a country who is debating whether the Prime Minister should be sacked for lying or notWaiting for the time when more companies, at least the engineering led ones, measure and publish performance metrics openly. Then we can move on to considering things that matter and not this sort of nonsense
