That’s not really what a higher sampling rate is about.No. Higher sampling rate captures higher frequencies. Which we can't hear anyway.
The sampling rate is simply how many times per second the analogue waveform is measured when it’s converted into digital. A higher sampling rate means more samples are taken, giving a more detailed mathematical representation of the original waveform.
Yes, by the Nyquist theorem a higher sampling rate also increases the maximum frequency that can be encoded (44.1 kHz → 22.05 kHz, 96 kHz → 48 kHz, etc.), but that’s only one consequence—not the primary engineering reason for using higher sample rates.
Higher sample rates can also:
• Reduce the steepness of the anti-aliasing and reconstruction filters, making them easier to design and potentially reducing unwanted artefacts.
• Improve the accuracy of time-domain reconstruction because the DAC has more information to work with between samples before interpolation.
• Reduce aliasing generated by DSP processes such as EQ, distortion, compression and synthesis (which is why professional recording is often done at 88.2, 96 or even 192 kHz).
Ultimately, the DAC still reconstructs a continuous analogue waveform from the samples. More samples don’t automatically mean audible improvements, but it’s incorrect to say the only benefit is capturing frequencies we can’t hear.
Imagine digitising a circle. If you record only 20 points around its circumference, software can reconstruct the circle, but it has to estimate more between each point. If you record 2,000 points, the reconstruction requires far less interpolation. Audio works on exactly the same principle: the waveform is sampled, then mathematically reconstructed.
