Chord Hugo 2 Review (Portable DAC & HP Amp)
Rate this DAC & HP Amp
    Votes: 80 25.1%
    Votes: 114 35.7%
  • 3. Fine (happy panther
    Votes: 92 28.8%
    Votes: 33 10.3%
Paradoxically, I am completely happy these days with a system that consists of devices NOT recommended in here.
And if they are electronics, it hardly matters.
Having had multiple demos involving a Chord DAVE, I could not fathom a universe where anyone would pay $10k+ for it.
Given that people did and possibly still do, that would simply be a failure of depth measurement tech, wouldn't it? ;)
It's a HUGE jolt to be told you spent $$$ in the thousands and got absolutely nothing extra to show for it. Especially if your significant other is also reading this material
:cool:
I suppose, but at the end of the day it isn't like the product itself is actually poor. You got what you paid for and are able to still enjoy it.
Sure it doesn't have a value aspect to it, but it isn't like you bought something that is broken and paid a ton of money for it like the people who wasted money on AudioGD stuff.
True enough.
I know if I told my wife that I had spent £10k on something when I could have got the same performance for £500 (or less) she might start wondering about my sanity (more than she does already!)
I guess if money is no object then nobody cares. But even if that were the case with me, I’d want to get value for money - I’d be spending the £9500 saved on the family, etc.
It’s nearly impossible these days to tell fake or synthesized/cultured jewels from real ones while wearing them.
A Goyard Bag costs a ridiculous amount and an exact replica costs less than a tenth.
What was the banana-taped-to-wall art really worth?
These sorts of conversations can cut many ways.
“I am not a fan of two separate USB inputs one for data and the other for charging. Why not charge using the data connection?”
So you can charge and use the usb data input at the same time, I guess.
You don't need two ports for that. Every standard USB cable has wires for power and signal/data. 'Data only' / 'power only' connections are possible ofc (you can disconnect pins or put tape on them:)), but the standard connection carries both.
See: https://en.wikipedia.org/wiki/USB_hardware#Properties
So it's a design choice they made. Upside is, it won't start draining your phone's battery suddenly (charging switches aren't that common IME)
