Definitely not if you look at Amir's Hugo TT2 , Qutest, Hugo2, Mojo2 measurements - all top tier measurementsI think he's no idiot though.
Dave is the oldest of all current production
Does not seem to match Amir’s measurements; not sure why they are different.The only thing that makes me wonder is this (taken from Goldensound's measurements):
You go to all the lengths of creating a really steep filter, and then have it provide only 40dB of attenuation before Nyquist. Why???
Mani.
So noted. Is there a DAC with a sharper attenuation at Nyquist that does not start declining before 20 kHz?The attenuation at Nyquist is similar actually. GS's shows ~40dB, Amir's ~45dB. Why Amir didn't pick up and comment on this, I don't know.
(Amir's signal is at 0dB, GS's at -60dB.)
Mani.
From my experience, upsampling does change the sound quality, but it's not like the change you experienced with your friend's Chord system. I don't like the sound quality of upsampling; I prefer the original sound.Well, I went to a friend's house today and listened to his system for the first time. He has a Chord Dave and the accompanying Chord upsampler. He told me the upsampler made a huge difference. I didn't believe him. So he tried a few settings ... 44.1, 96kHz, 192kHz ... and the difference was indeed dramatic. As the sample rate went up, the sound became leaner with a more pronounced top end!
I told him there is some kind of DSP jiggery-pokery going on. There is NO WAY that changing sample rate makes that much of a difference. I am convinced that the Chord upsampler must be applying some kind of shelf filter. Sadly, Amir only had access to the Dave and not the upsampler, because I would LOVE to see what kind of fraud Chord is committing here.
Or it’s all in your head… we do have a review of the upsampler:Well, I went to a friend's house today and listened to his system for the first time. He has a Chord Dave and the accompanying Chord upsampler. He told me the upsampler made a huge difference. I didn't believe him. So he tried a few settings ... 44.1, 96kHz, 192kHz ... and the difference was indeed dramatic. As the sample rate went up, the sound became leaner with a more pronounced top end!
www.audiosciencereview.com
Even the cheap Motu M2 has such a filter.Sure:
(Though I have to say there's some discussion as to whether it's the DAC's or OS's filter that's responsible for this performance. In any event, it's totally possible.)
Mani.
CHORD M-Scaler Review (Upsampler)
This is a review, listening tests and measurements of the CHORD Hugo M-scaler upsampling digital transport. It is on kind loan from a member and costs US $5,295 (some show it as $5,650). We have the usual lightshow of buttons as other CHORD digital products but here, due to less overloading...www.audiosciencereview.com
I agree. The only difference upsampling should make is to the reconstruction filter because the transition can be gentler, which in turn can only make a tiny difference to the analogue output.Well, I went to a friend's house today and listened to his system for the first time. He has a Chord Dave and the accompanying Chord upsampler. He told me the upsampler made a huge difference. I didn't believe him. So he tried a few settings ... 44.1, 96kHz, 192kHz ... and the difference was indeed dramatic. As the sample rate went up, the sound became leaner with a more pronounced top end!
Upsampling *should* make a marginal improvement because it makes the reconstruction filter easier to implement.From my experience, upsampling does change the sound quality, but it's not like the change you experienced with your friend's Chord system. I don't like the sound quality of upsampling; I prefer the original sound.
but not nearly as 'perfect' as Chord's
On the other hand with 44.1kHz there should be a steep low-pass filter on the recording/resampling side above 20kHz so attenuation only needs to be good at 24kHz.
Besides the signal level in actual music is already -50dB or lower (opposite 0dBFS) anyway and at 20kHz that is inaudible for mortal audiophiles.
Shouldn't that be 22 kHz (½ of 44)?
We should expect digital perfection for that sort of money.$6000 to insert a lot of jitter (although likely still not audible). What a strange world we occupy.
