JSmith
The principal behind is is to make money... nothing else whatsoever.the exact principle behind it
JSmith
Not sure if this is simply a big shorting plug, or if there is something inside the cylinder.
Crystals.
Not sure if this is simply a big shorting plug, or if there is something inside the cylinder. However, simple shorting plugs are prescribed in the service manual of my Mitsubishi DA-P20 Preamp for either the Moving Magnet Phono or the Moving Coil Phono input jacks when they have no cable connected to them and are otherwise unused. They provided one set of shorting jacks for the unused phono connections. Presumably having one set of open connectors on the unused phono input could interfere with the other phono input in a high interference environment (nearby police, fire, or radio station). Both inputs do end up in a common RIAA amplifier.
I guess it's reasonable for a high gain phono stage's input connectors, but wouldn't think it would matter for line level inputs.
Yes, its possible though I doubt its just a big shorting plug. I bleieve there must be something in that tube. But what it is, its quite impossible to know without ripping it apart.
Maybe a 10 ohm resistor?
Actually when I saw the one with a BNC connector I figured a 50 or 75 ohm resistor, and then reminded myself it was an audio application.
Maybe its diode? Sicne it says provides a low resistance path, so diode will provide a 1 way path. I am tempted to get it and see what is inside. But AUD1K gone just for this is a little hard to stomach.
The potential interference (RF) is AC so a single diode could cause interference by only providing a path to ground for one half of the AC wave. Back to back diodes are often used to protect delicate receive circuits in a transceiver but need to be carefully designed so that they do not introduce IMD.
The GroundARAY is a cylindrical design made from precision CNC-machined thick-walled aluminium; the thick walls themselves stop the device from contributing HF noise. Available in six termination options, including USB A, RCA and XLR, for a wide range of digital and analogue A/V devices, the GroundARAY benefits from five separate noise-reduction systems, all working across different HF noise ranges and operating in parallel to convert undesirable HF electrical noise into heat.
The advanced technologies provide a very low-impedance, high-bandwidth route for HF noise to pass into, effectively ‘pulling’ noise from the signal ground of the host equipment.Each GroundARAY cylinder is filled with a carefully chosen material to deaden noise. The final assembly is then locked into place to reduce any effects from acoustic vibration.
Giving crap like this even the slightest shred of credibility is the mark of an ignoramus. Unless you're the one peddling it.
Are you by chance directing your ignoramus comment towards me?
That's an odd reading.
https://chord.co.uk/chord-history/My source on their relationship was an insider. That doesn’t mean it’s right, but it was from someone in a position to know.
If there were no connection, so to speak, there would likely be trademark litigation.
https://chordelectronics.co.uk/john-franks-chord-electronics-took-flight
Maybe the UK’s a little less keen on costly litigation.
Or maybe neither company feels the other is adversely affecting their reputation, a bit like the Rolls Royce and Brough Superior story from the 1930s.
https://www.motorbiscuit.com/brough-superior-the-rolls-royce-of-motorcycles/
I'm surprised you'd form a conclusion based on hearsay and a loose theory.My source on their relationship was an insider. That doesn’t mean it’s right, but it was from someone in a position to know.
I think you’re right. It is confusing for the average consumer, but if it doesn’t adversely affect either company’s business, and neither company has any interest in producing the other’s products, there’s really no reason to go to the expense of litigation.I am inclined to believe that many people think they are the same company.
