Chord Co Taylon
Brierlox
Hi all. I read the attached the other night and was so moved to laughter I thought I would share
Taylon Blurb
It seems to make out that PTFE is not "Phase stable" at normal room temps. I'm open to correction but isn't PTFE extremely stable at temps circa 18-25 degrees. What does "Phase Stable" even mean?
This company shares no information on even the materials used in the construction of their cables. The also use cheap as chips connectors to terminate their XLR and Power cables so I can see no reason why their mid to hi cables are circa $1,000 when they seem to be constructed entirely of snake oil. I am still waiting for an answer as to what their cables are made of (copper, silver, silver plated copper etc.) and what phase stable means.
Maybe an admin could ask for same?
Grok AI:
Does PFTE have some sort of molecular change around room temperature?
Yes, PTFE (polytetrafluoroethylene), commonly known as Teflon, undergoes a well-documented molecular transition near room temperature that affects its physical and electrical properties. This transition is related to changes in its crystalline structure and molecular arrangement, which can influence its performance as a dielectric in applications like audio cables. Below, I explain the nature of this transition, its temperature range, and its relevance to dielectric properties, particularly in the context of your earlier questions about phase stability in audio cables.
Molecular Transition in PTFE Near Room Temperature
PTFE is a semi-crystalline polymer with a complex molecular structure composed of long chains of carbon atoms bonded to fluorine atoms. It exhibits several phase transitions as temperature changes, with one occurring near room temperature:
  1. Phase Transition at ~19°C (66°F):
    • PTFE undergoes a first-order crystalline phase transition around 19°C, often referred to as the Phase II to Phase I transition.
    • Below 19°C, PTFE exists in a triclinic crystal structure (Phase II), where the molecular chains are tightly packed in a highly ordered, helical conformation (approximately 13 carbon atoms per 180° turn).
    • Above 19°C, it transitions to a hexagonal crystal structure (Phase I), where the chains adopt a slightly less ordered helical conformation (approximately 15 carbon atoms per 180° turn). This is due to increased molecular motion and slight unwinding of the helical chains.
    • This transition involves a small change in the packing density and molecular alignment, leading to a slight expansion in volume (on the order of ~1–1.5%).
  2. Additional Transition at ~30°C (86°F):
    • A secondary transition, sometimes called the Phase I to Phase IV transition, occurs around 30°C. This is less pronounced and involves further relaxation of the molecular chains, with increased rotational freedom.
    • This transition is less significant for most applications but contributes to subtle changes in mechanical and electrical properties.
Impact on Physical and Electrical Properties
The molecular transition at ~19°C (and to a lesser extent at ~30°C) causes measurable changes in PTFE’s properties, which are relevant to its use as a dielectric:
  • Density: The slight volume expansion at 19°C results in a small decrease in density (e.g., from ~2.15 g/cm³ to ~2.13 g/cm³). This is due to the less compact hexagonal phase.
  • Dielectric Constant (ε_r): The dielectric constant of PTFE, typically ~2.1 at room temperature, may exhibit a slight increase or decrease (on the order of 0.01–0.1%) across the 19°C transition due to changes in molecular packing and polarizability. The exact change depends on frequency and measurement conditions, but PTFE’s dielectric constant remains highly stable compared to other polymers.
  • Loss Tangent: PTFE’s loss tangent (~0.0002 at audio frequencies) remains extremely low and is minimally affected by the transition, ensuring low signal loss.
  • Mechanical Properties: The transition can cause a slight softening or change in stiffness, which may affect the flexibility of PTFE-insulated cables. This is more relevant in mechanical applications than electrical ones.
Relevance to Audio Cables and Phase Stability
In your earlier question, we calculated that PTFE in a 1-meter audio cable causes a negligible phase change (~0.00035 degrees at 20 kHz) over a 0°C to 40°C temperature range, assuming a dielectric constant change of ~2%. The molecular transition at ~19°C contributes to this change but is a minor factor:
  • Dielectric Constant Variation: The phase transition at 19°C causes a small shift in ε_r, estimated at 0.01–0.1% per °C in the transition region. For a narrow temperature range (e.g., 15°C to 25°C, crossing the 19°C transition), the change might be on the order of 0.1–0.5% total. This is much smaller than the conservative 2% assumed in the prior calculation, confirming that the phase change remains inaudible.
  • Phase Impact: Using the phase shift formula from before:
    Δφ ≈ φ * (Δε_r / (2 * ε_r))
    If Δε_r / ε_r ≈ 0.005 (0.5%) across the 19°C transition, the phase change at 20 kHz for a 1-meter cable (base phase ~0.0347 degrees) is:
    Δφ ≈ 0.0347 * (0.005 / 2) = 0.0347 * 0.0025 = 0.00008675 degrees ≈ 0.087 millidegrees
    This is even smaller than the previously estimated 0.347 millidegrees, reinforcing that the molecular transition has a negligible effect on audio signal phase.
  • Audibility: Phase shifts below 1–2 degrees are generally inaudible, especially at 20 kHz, where human hearing is less sensitive. The 19°C transition’s impact is far below this threshold, making it irrelevant for audio cable performance in typical room conditions (e.g., 15°C to 30°C).
Comparison with Other Dielectrics
Unlike PTFE, other dielectrics like PVC or polyethylene do not exhibit sharp crystalline phase transitions near room temperature but may have broader glass transition temperatures or less stable dielectric properties. PTFE’s molecular transition is unique due to its highly fluorinated, crystalline structure, but its dielectric stability remains superior, even across the 19°C transition.
Practical Considerations
  • Room Temperature Range: In typical room environments (15°C to 30°C), the 19°C transition is often crossed, but its effect on dielectric performance is minimal. High-end audio cables using PTFE (or proprietary materials like Taylon®) are designed to maintain phase stability regardless of such transitions.
  • Extreme Conditions: PTFE’s stability extends well beyond room temperature (up to ~260°C), so the 19°C transition is not a limiting factor compared to its performance in harsher environments.
  • Cable Design: The overall phase stability of an audio cable depends on factors beyond the dielectric, such as conductor geometry and shielding. PTFE’s molecular transition is a minor contributor compared to these.
Final Answer
Yes, PTFE undergoes a molecular phase transition around 19°C (and a secondary one at 30°C), shifting from a triclinic to a hexagonal crystalline structure. This causes a slight change in its dielectric constant (0.1–0.5% across the transition), resulting in a negligible phase change in audio cables (0.087 millidegrees at 20 kHz for a 1-meter cable). This is far below audible thresholds, confirming PTFE’s excellent phase stability as a dielectric in audio applications, even across room temperature variations.
