CHORD Alto Headphone/Power Amp Review
Rate this headphone and power amplifier:
    Votes: 246 65.1%
    Votes: 104 27.5%
    Votes: 22 5.8%
    Votes: 6 1.6%
In most pro applications power is absolutely the main quality metric. (Ie. SINAD, FR etc all go out the window if you're clipping...)
For headphones? Like most people here, I don't quite get this product.
BUT it must have use cases. I assume being basically a speaker amp this will drive 8 ohms on the HP outputs? Such that, where the same mix is sent to a number of people (E.g. large orchestra sections, crowds, choir etc) you could parallel lots off this. Doesn't seem like that's it's intended use though, given the form factor and connectivity.
In terms of recommendation, yes of course, it'll sound OK and it's very powerful, so it's recommended if that's your requirement. Amir always quantifies his recommendations.
The one thing that surprises me is that form factor. Anything that isn't 19" isn't really pro, is it!? At least for this kind of thing. I always think; what would an Amazon data center look like if they used laptops with a bunch of USB SSDs hanging off them, instead of servers? That's basically what your studio or touring rig will look like if you start buying too much stuff that could go in the rack, but doesn't... especially with external power bricks!
It is extremely strange to see a $4,000 distortion generator to be "recommended" on this platform. Maybe it has warm slam, dynamic timbre, textured imaging, and good decay without sibilance, who knows...
It seems like one of those Rotten Tomatoes ratings with 98% from the "critics" and 11% from the audience.
Thank you for the review,
I would've voted for this threesome and get 3 pink 'chords' for free.
I think I read some place that it is half rack.
Ah, I see. If that's the case I (partially) retract my criticism.
Still, I find it hard to imagine a pro setup where having a desktop sized headphone amp and external power brick is preferable to a full width 1U with ears and PSU inside, IMHO. But again, I guess they did at least *some* market research and found otherwise.
@amirm
Can you please explain why the Bluesound Node Streamer, which measures -117, got a frowny panther for not having a proper filter yet this thing gets a happy panther at a miserable -85? At $4700? DOES NOT MAKE SENSE. And you've bitched about their crappy interface before, but now needing a cheat sheet is just fine? I'm afraid you're not being consistent here. I certainly wouldn't spend almost $5k for a glorified headphone amp with an unusable power amp. What am I supposed to do with a distortiony 50w of crappy amp? And a headphone amp that measures -85?!? That doesn't even pass CD! I'm afraid your panthers are skewered. This turd needs flushed, IMO.
A streamer vs. a headphones/power amp is like apples and oranges: how do you compare them? Amir’s ratings are subjective… what if he prefers the oranges?
@amirm
Honestly, this is hardly the first overpriced, moderately performing product we’ve seen. Why is there so much emotion related to this one?
Amir can’t win, he gets criticised if he goes in too hard on Chord products, then criticised when he frames his opinion on the good bits this product offers.
@amirm
This unit fits in well with all the other so-called 'High End' products with iffy to good-enough performance (good by 11970s standards) and sky-high prices. This site and its reviews are almost certainly regarded as a load of measurement 'cranks' assuming they even know if ASRs existence, which I doubt most of them do... These people will wander into their local audio salon, have a gander (casual look) at the new bling-boxes on show and this little trinket will no doubt find a place either for headphones, or the setup in the dining room (what better for Tune-Tots?).
@amirm
You seem to be under the mistaken impression that whether a product gets a recommendation is solely about the SINAD figure. Also, a streamer is not an amp. Also also, the reasoning for recommending or not recommending was explained in both reviews. Whether Amir recommends or does not recommend something is his personal opinion. You don't have to agree with it and have the data to make up your own mind.
Do any headphones require this sort of power?
Just wondering what the use case is?
Use case is, it has up to 4 sockets for 4 different headphones in case you want to conduct A/B/C/D tests or invite your 3 best friends all listening at the same time sitting around the Alto.
Question to the “audio-pros”: would it be better if it was a full rack size (instead of half) with an integrated PSU (instead of separate)? Or there are pros & cons? Or it doesn’t really matter…?
The Pro for a separate power supply is that if it goes bad, it is easy to diagnose and replace. It also distributes the heat better (two separate boxes).
The con is convenience. For rack mounted gear, it is usually zip tied somewhere in there. Not great but doable.
As I have explained repeatedly, cost does not normally enter my recommendations unless we are talking about something ultra cheap. What is affordable for me may not be for others and vice versa. You all can of course incorporate it into your voting. That is why that system was put in place: so that membership could express their recommendation and not keep trying to change mine.
Well Said Sir
AND I do not disprosition it
IF @AMIRIM OCCURS
