never going to get close to digital quality.
absolutely false... I get close generally and sometimes better or much worse... but talking about recommendations... never is a really false thesis in my experience.
www.audiosciencereview.com
Nope, I will buy. I don't have any =(I'm getting that you don't have a record collection to play as some of us oldies do?
I know, it's okay.PLEASE bear in mind that most newly purchased vinyl today, appears to come from a digital master
Thanks, I'm already starting to make a list of which ones to take a closer look at =)would start at a AT LP5X with VMN95ML or VMN95SH stylus upgrade (£500 or less). Rather than get a 1200mk7, I'd arguably save and get a 1500C with Ortofon 2M Red for £799 here (phono stage built in too). Your budget could stretch to a 2M Bronze stylus, which should clean the highs a bit further without losing sparkle and 'energy.'
If you are copying vinyl to a PC you can clean up the sound with something like Vinyl Studio. On most records, once you are used toit, it takes about 10 mins more than the playing time. I've recovered some pretty unlistenable old recordsThanks for your opinion. Yes, I am aware that vinyl is one of the worst formats for clear sound. And one of the most inconvenient.
I just like how it's physically designed (turntables, cartridges), how it's made, how vinyl records look. Let's say it's more of a ritual and interest than a desire for objectively good sound =)
For "good" sound, of course, I have a PC + dx9 and others. I understand that they are much cheaper and sound much better, objectively. And they don't require any maintenance, essentially.
Hi Bl00dWolf. Dedicated vinyl lover here. The vinyl/digital debate is silly and will never end. By any empirical measurement digital is infinitely better and has been for decades.Hello.
I want to get into listening to vinyl.
I would appreciate any advice you can give me, thank you very much!
drive.google.com
they all have varying degrees of wear and clicks
drive.google.com
My sl-100c have vta... the autolift can be turned off.With the price tag difference between 100C and mk7... I'd get the mk7 with eyes closed.
Mk7 have helicoidal tonearm vta adjustment (sl100c doesn't have vta adjustment) and sl100c have an "autolift", that means a mechanical gadget added to the tonearm (I don't like to have any stuff glued to the tonearm).
My opinion only.
Does it? A sensor can take many shapes.sl100c have an "autolift", that means a mechanical gadget added to the tonearm
Why? How can you tell something is "glued on"?(I don't like to have any stuff glued to the tonearm
Autolift integrated means you have a mechanical device attached to the tonearm movement. I don't like it.
I also don't like the integrated preamp.
. Very scientific.Yes, you're rightThe 100C comes without the integrated preamp, you're thinking of the 1500C...
And you are very disrespectfulYou are a crazy MF
. Very scientific.
Tell us this science. Show us the "glued on " part. Show us a bad sensorsystem, tell us why. This is science, so prove it. Unless you are relying on old mythical bs from the old days, when "auto" was a bad thing no matter, based on "audiophile" beliefs. You are not my friend, and I don't think you will be.Maybe you don't know the science behind physics and vibrations in a mechanical device.
It's not my fault my friend.
Ignorance usually brings more confidence than knowledge.
